Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: CAN 11-bit addressing - help?
  1. #11
    Jul 2005
    Michigan
    I see... Source Destination stuff is possible obviously, but I personally have never seen like you see in Class 2 3 byte headers or ISO 9141. As was mentioned earlier, 29bit is definitely used as a Priority/Destination/Source addressing scheme, but is a lot of overhead for most high speed applications. So typically you wont see too many manufacturers use 29bit for their Powertrain buses, but rather for their Chassis buses.
    You are definitely on the right track. Reverse engineering is the only way to figure out what is going on here.
    After you have finished with your Reverse engineering what do you plan on doing with the info? Are you going to post it somewhere?
  2. #12
    Mar 2007
    Rutherford, Australia
    Will I post?
    I most certainly will. In fact, I have started already. The details, however, are a bit long-winded, and while I'd like to describe it all, I'm not sure if this is the topic or indeed the Forum that I should use.
    As this work is all being done on an Australia specific car that is sold only in Australia, New Zealand and South Africa I will be focussing on that, so international relevance may be limited.
    If you're interested I have at least started posting on an Australia Ford Modifications here: www.fordmods.com :: View topic - SCANTOOL Fun
    But at the moment you'll only find me rehashing the basics. The gory detail of reverse-engineering Broadcast messages or verifying my current (very small) list of Ford Enhanced PIDS is yet to be done but will likely be journalled in that thread.
    The eventual intention is to write some sort of utility that can be integrated with a Media Centre application so that it can be shown on the existing NTSC RGB LCD screen installed in these cars from the factory, such that I can review Polled or Broadcast data with the use of a simple remote control.
    The capture of data from other Scantools, however, is more about extending my knowledge of the comms in this car than it is about having a goal, and about discovering more of the PIDs that might interest me.
    I was initially triggered by the desire to upgrade from a Manual Climate Control console in one of my cars to an Auto Climate Control console, which requires writing some new values to the Body Control Module and HVAC Control Module. The proprietary nature of the data involved of course prevents me from doing this easily, but by 'piggy backing' on the guys at the dealer workshop if I ever get them to do this work for me means that I'll at least understand how it was done. (If I can capture the bits quick enough that is.)
    One of my other projects was to access the factory screen and use if for displaying an in-car LCD camera faced at the back seat (so I can see my kids at night) and a camera at the rear for reversing, or for putting on the back of our Caravan so I don't have to install 'Wing Mirrors' and scratch my car when I go on long trips.
    Plus, in many ways, I'm just doing it for the fun of it because I am a hopeless techo head.
    Lukeyson
  3. #13
    Apr 2010
    communication protocol 15765
    Hello
    I am newbie in C, in fact I have a project on the management of CAN messages (ISO 15765-3 and -2), and I'm struggling to set the structure of my message.I explain:
    in the application layer communication protocol there is a message char * a larger than 8 bytes and the network layer must add 3 bytes of identification and we need to cut (the message+3 bytes) for 8-pack bytes and send it like ( single frame , first frame , consecutives frame and flow contril).
    my problem is that I know not where to start, if anyone can help or has any exemple of (.C or .cpp) I pressed very grateful.
    Very cordially
  1. Core Duo/Core 2 Duo processors
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 02-06-2007, 09:00 PM
  2. 32 bit color or 16 bit color
    By jackdon in forum Road Runner
    Last Post: 09-08-2006, 10:11 AM
  3. what bit is this?
    By W6-Ryan in forum LCD/Display
    Last Post: 03-17-2002, 05:55 PM
  4. sproggy power supply drill bit size?
    By Ces///M3 in forum Power Supplies
    Last Post: 10-08-2001, 10:19 AM
  5. 20 bit = high color or 256 ??
    By hippie in forum LCD/Display
    Last Post: 05-08-2001, 10:12 AM
