Results 21 to 30 of 39
Thread: Battling summertime heat issues . . .
  1. #21
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    Xenarc 700TSV + Old School Lilliput 7" TS survived the heat here in Australia when it was about 45 * C outside
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
  2. #22
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    kirk78h, if your comp dies at 80F (26C) maybe there something wrong with the components... 26C is regular temp for comps. I actually have 26C in my room rightnow. So check components and see what exactly causing the failure. You siuld not see problems at least untill temp heat 32-40C
    Road Camera HD - Backup Camera Plugin + Mobile DVR BlackBox [Completed]
    Acura / Honda A/V CarPC Adapter GA-NET+ - Convert your native navi DVD unit to CarPC + Dash buttons are usable in car pc!!!
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
  3. #23
    Constant Bitrate archaic0's Avatar
    Jan 2007
    McAlester, OK
    My touch screen is pretty much in direct sunlight at times in parking lots and while the screen hasn't failed, the case of the screen has warped a little. It hasn't effected operation as of yet, but it makes me want to get some kind of silver reflective cover for it maybe when I know it'll be in the sun for a while parked.
    As for cooling options, the peltier idea has been mentioned over and over through the years and I think I'm about to attempt a peltier solution. Most people go directly to one of two things when it comes to peltiers: condensation or the excess heat from the hot side of the thing. I think it can be managed though if the point is to simply make sure something like a trunk is in an operating range. The purpose isn't to get the computer or the environment down to 'cold' temperatures, but simply to bring the environment down under that 100F / 38C threshold that seems to be a breaking point sometimes.
    My idea would be to install a peltier under the spare tire with the hot side of the device exposed to the outside air. Then have a fan blowing across the cold side into the trunk.
    The air coming off the peltier may be super cold, but by the time it mixes with the trunk air when it's over 100F/38C I can't see the trunk getting much cooler than 80F/27C.
    With that kind of a setup you would have a small footprint for the cooler, it would be out of the way, and I can't see any condensation issues since there's no way a small peltier could get an entire trunk down to a dew point. But it should be able to get the environment just that little bit cooler that the components like.
    Comments?
  4. #24
    Newbie thejavabuddha's Avatar
    Jul 2009
    You will HAVE to post details on how this works out!
  5. #25
    Jan 2007
    McAlester, OK
    I've been shopping for a peltier to use and I think I'm going to gut a portable 12v cooler to make my solution. They advertise being able to drop that small space down 40 degrees under ambient (so down to 70 degrees from 100). I think that should be perfectly sufficient for a car trunk. I'm thinking that I'll make a square duct from the bottom center of the tire well where the peltier will live to the back of the trunk (towards the rear of the car) for input air. Then I'll have a fan vertical in front of the peltier blowing across it to a square duct that exits towards the front of the car.
    I wonder if I should mount a heatsink to the cold side to blow through? That makes sense right? (anyone who's worked with peltiers know the answer to that?) If it works for heat it'll work for cold too since it's the same principle I think.
  6. #26
    Jan 2007
    McAlester, OK
    I did a quick mockup just in case anyone didn't follow what I meant. Obviously the scale is way off, but this is the idea.
    The target temperature for the trunk would be 80F / 27C when it's 100F / 38C outside.
    http://www.dvigroup.net/share/pictur..._diagram_1.jpg
    This also has the side benefit of cooling my car stereo amp. I don't thermal it very often, but on very hot days while I'm on a road trip and thumping pretty hard down the highway it's been known to happen. I usually just drop the back seat down to help my air get to it from the front in those cases.
  7. #27
    Maximum Bitrate hexxamillion's Avatar
    Dec 2007
    AZ
    I'm interested to see what the final solution you use for ambient cooling. I have been brainstorming a solution for this for a while for use with in-car solar power.
    See my post regarding using solar energy in the car. I am still brainstorming this and my second main issue how to relieve some of the heat in my car while it is idle. I live in climates that can reach up to 120F in the summer. Imagine how hot that it ends up being inside the car. http://www.mp3car.com/vbulletin/how-...ur-laptop.html
    So yes, I am curious to see what your cooling solution will end up being.
    ....I just wanted to add on other thing..it's funny someone in this post mentioned the idea of gutting a 12v portable cooler...LOL! I was investigating that idea also.
    "Live Free!!!...It's all about Open Source"
    Worklog:'09 Altima Android Tablet PC Dash Mount
    Old project'05 Nissan Altima Project (Intel D945GCLF2D)
    Vimeo Vids:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  8. #28
    Jul 2009
    My question is how much power (electricity) does it take to drop the temp by 30 degrees? Would it overload the battery between an amp, pc, and a cooler for the trunk? I'm sure the little fan wouldn't take up all that much, but I know heating stuff takes a lot of juice so I imagine doing the opposite would require a fair amount too.
  9. #29
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    why don't you go in the offensive instead of the defensive and tint your windows, my car dropped 10 -15 degrees since i got my windows tinted.
    PS: don't cheap out on the film buy the good stuff, it'll work better and it won't fade or peel off, i got Formula1
  10. #30
    Jan 2007
    McAlester, OK
    My windows are tinted now, and the environment outside ranges from 90-110 outside usually but can climb a little higher. My stuff is in the trunk, out of the sun completely so the tint didn't change the trunk temp of 90-100 after being in a parking lot for several hours.
    No matter how dark it is in the trunk, it's still a metal box sitting in the sun. So eventually it will at least match the ambiant air outside. With insulation you might be able to keep it 5-10 degrees lower, but that may not be enough.
    People reference the trunk being MUCH cooler than the car, and that's usually true since on a 100 degree day the inside of the car can get to 140 or 150 easy with the right conditions. The trunk will still be close to 100 though and that's too hot for a lot of the components to be running at.
    My biggest problem right now is actually my startup/shutdown controller. The PC itself has never had a glitch even up to 120 degrees. The cpu and hard drive are kicking just fine, but that startup/shutdown controller starts fritzing out at 100 or so. It may not be GOOD for the PC to run that hot, but it will run none the less. The startup/shutdown controller isn't as tollerant.
    Which is how *I* got to this peltier idea. The cooling should allow the startup/shutdown controller to function, and as a bonus the PC will be much happier.
    I'm sure the current draw for the peltier is pretty high, but part of MY plan anyway is to put in a second battery with an isolator (seperate from the heat issue, I have a voltage drop issue now since the PC is right off the car power since I'm using a simple startup/shutdown controller instead of a DC power supply). The peltier would be powered off the second battery along with the PC while my stereo amp would remain on the normal power.
    If the second battery dies, that's fine. But I bet I could come up with something that delays the starting of the peltier until I unlock my doors. And that same delay component might delay the startup/shutdown controller as well. Just to give the peltier a minute or two to start pushing some cool air around.
  1. Touchscreen Issues w/Hibernation & CNX-P1290
    By jmciver in forum Power Supplies
    Last Post: 12-20-2006, 08:48 PM
  2. Verizon Novatel 620 issues
    By MobiTekLink in forum Wireless Communications
    Last Post: 12-02-2005, 04:35 PM
  3. To heat sink or not to heat sink ...
    By jnusaira in forum Newbie
    Last Post: 02-18-2004, 10:46 AM
  4. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 03:14 AM
  5. COOLING THE CARPUTER
    By moahdib in forum General Hardware Discussion
    Last Post: 07-04-2002, 09:18 AM
