Originally Posted by
CMOS1138
I once water cooled my desktop system in order to keep it quiet so I do not view water cooling as scary. I would actually consider water cooling in a car to be even more reasonable than at home since the car is already water cooled. A transmission cooling kit that adds a 2nd small radiator could be readily modified for pc use. To me the only reason to consider this solution though is if you are running an overpowered carputer (or a system like HiJackZX1's ;) )and you install it in the cabin, otherwise standard pc cooling should be enough.
