Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: Extreme Temperatures
    Jul 2009
    First off, this is my first post after lurking for a while. What a great site with so many people doing cool things. Just want to say thanks to everybody who contributes here.
    Anyway, we are getting a new pickup in which I am considering putting in a carputer - that is how I found this site. One concern I have is that we live most of the year in Arizona and part of the year in Park City, UT. So, while we would spend most of the summer time in Utah, we will still be in AZ quite often during the summer and while we will be spending most of the winter in AZ, we will be in Utah quite often while it is really cold.
    What would I need to do to prevent damage to any of the equipment that will be in extreme heat (110F+ outside) and extreme cold (below 0F)? I searched around the forums for an answer, but couldn't really find much about it. I did see that keeping it in the trunk is helpful, but this will be a pickup truck with no trunk.
    PS - if it matters much, I plan to mostly be using it for basic stuff like music, gps and a streaming internet connection.
    TIA.
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Meridian, Mississippi
    Mmmm water cooling if you have the guts to do it. what would scare me about doing that would be bumps and pot holes... (air bag susp might help?) Or even crazier would be a submersion!!
    Oh, just had another thought... On most trucks their is unused spaced before and after the rear tires between the outer skin and the bed might be a good spot for a comp guess it would depend on the truck.
    May 2006
    Calgary, Alberta
    That's not extreme, my computer goes through worse every year. In the winter here it gets to -50 and last year I drove my car down to Atlanta for 6 months where it was 40 degrees. The computer powered through both extremes and those temperatures are higher/lower than the ones you posted.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Feb 2009
    Finland
    I've used my carputer when outside T was about -33C (about -27,4F) and +30C (about 86F). Worked normally without any issues. Nothing special were used to build a system...
    May 2009
    Florida
    Remember that the computer doesn't need to be powerful for in car applications. You can use a CPU with low power consumption and install a case fan (dc power supplies don’t have them) if you are concerned about it.
    Jan 2008
    Norton, MA
    not sure what truck you are getting but I would think installing inside the cab in some configuration would be the easiest. Mine is installed behind the back seat with my amplifiers.
    Only problem I could possible see with extreme temps would be with standard mechanical hard drives. Many have some sort of a liquid lubrication inside of them and this can be affected by the temperature. I don't recall all the times but mine has started up in 0° on several occasions. This took multiple pushes of the power button over maybe 5 minutes however the PC did eventually boot up.
    This is also with a "ancient" Maxtor 120GB IDI drive, I figured I would use a old spare drive I had laying around as a test drive in my truck just incase the bumps (1 ton suspension) or temperatures (0°-100°+) were going to cause issues. So far 1 year or so and absolutely no hiccups other than what I mentioned with I guess hard cold starts.
    2005 Ford F-350 crew cab 4x4 6.0L SRW LWB
    Planning:
    [|||||||||-] 95%
    Parts Aquisition:
    [||||||----] 60%
    Install:
    [|||||||||-] 90%
    Finally getting Built
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Water cooling is abit overkill and scary to use. One hose pops off and your done. WuNgUn is the only one that I have seen do a successful water cooled system. Me, I live in FL, which isn't quite as hot as AZ, but its pretty close. I use a uniquely designed case that forces alot of air past the system, Since my AMD based board generates more heat then I like. Even with no A/C at the moment, with cabin heat, the PC will rapidly drop in temperature once turned on. Once the A/C is on the temperature drop is so massive, due to a design flaw, that turned out to be good. Basically the front center console has two fans that draw air in, then push it out the back. It just so happens those fans actually draw in A/C air. Since the second console is directly behind the first, so it actually drew that air in. I have since redesigned the consoles so they are one long unit, so all the air is very slightly chilled for the Car PC. To avoid moisture issues, I made it a 2 chamber system, so if it does happen, alot of it gets caught in the first.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    May 2009
    Florida
    I once water cooled my desktop system in order to keep it quiet so I do not view water cooling as scary. I would actually consider water cooling in a car to be even more reasonable than at home since the car is already water cooled. A transmission cooling kit that adds a 2nd small radiator could be readily modified for pc use. To me the only reason to consider this solution though is if you are running an overpowered carputer (or a system like HiJackZX1's )and you install it in the cabin, otherwise standard pc cooling should be enough.
    Jul 2007
    Miami
    Quote Originally Posted by CMOS1138 View Post
    LOL, please take note. A psycho that has A.D.D, and thinks on massive scales = a system like mine. CMOS1138, where in FL u at?
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    May 2009
    Florida
    I live in Tampa. I wanted to go to the last Florida meet but unfortunetely I have no free time.
  1. Sandisk Extreme III cannot be set to fixed disk
    By knubile in forum WinNT Based
    Last Post: 01-06-2005, 03:01 PM
  2. Need Help with Radio Extreme.
    By shak in forum General Hardware Discussion
    Last Post: 12-20-2004, 01:09 AM
  3. harddrives withstanding cold temperatures?
    By Nick DC in forum Newbie
    Last Post: 12-11-2004, 10:37 AM
  4. Temperatures Extreme a problem?
    By Lebult in forum Newbie
    Last Post: 05-01-2004, 12:51 PM
