Results 1 to 7 of 7
Thread: computers and loud stereos?
    Dec 2009
    I'm debating installing a car PC in my Chevy Blazer and one of my primary concerns is damage resulting from my stereo, in particular the bass frequencies. I have broken various parts of my car's interior already (mirror, trim panels, lights, console latches) so I'm worried a motherboard might be damaged. I was planning on using an SSD hard drive.
    Is this a valid concern firstly? And second are there ways to manage or deal with this?
    Low Bitrate pulsarsimon's Avatar
    Nov 2009
    Melbourne Australia
    turn it down a bit?
    just kidding.
    if the board is mounted with some 'shock absorbing' mounts, that should give it ample protection... unless you want to fork out for an industrial-type PC.. $$$$$$$
    MacMini in an Alfa? - Why not!
    May 2007
    I use to run a system from http://mo-co-so.com/ there built well and they can withstand the punishment. I had an insanely loud system in my 04 Durango before it was totaled by a stupid stop sign runner. The base was low and hit hard and the only thing it couldn't withstand was said stop sign runner. Hope this helps with your decision.
    Low Bitrate IssaquahWA1979's Avatar
    Oct 2009
    Issaquah Washington
    most motherboards are built better than the Chevy Blazer, I would do a isolator setup on the board mount and call it good.
    Custom Built Intel D510MO, 2GB RAM, M4-ATX, Elios 15" TS on custom mount.
    System installed into 2005 Dodge Ram 3500 Cummins Diesel 4x4.
    I can provide Custom fabrication for mounts or installation please contact me. CNC Machining and Powder Coating
    Feb 2008
    Houston
    Quote Originally Posted by creyc View Post
    I know it is a valid concern. I have a pc in my odyssey. Extreme bass caused me several problems. The hard drive didn't like it. Solid state IS necessary. Anything in a slot had to be secured well. if you ever get a blue screen right on a strong bass note, it is probably the pci cards wiggling. the last problem for me was low vehicle voltage (after jammin' for a while) causing the power supply to shut off. I got a Kenetik 1800 and isolated it. make sure to isolate it from whatever batteries your sub amps are on. Problem solved. it is also convenient to run pc while car is off, and have no battery worries, just shut off that low low amp....lol
    Elsewhere
    Quote Originally Posted by derek156 View Post
    I think that mounting your HDD securely to a component that is not going to vibrated to death by the bass is necessary, but the expense of an SSD is not.
    Granted, there are benefits to an SSD, without question, but I don't believe your statement is accurate as long as the installer takes vibration of the HDD into consideration.
    I'd shoot for better than just "well", regardless of how extreme your bass is. Mere road vibration can cause expansion cards to wiggle loose.
    How about the Wiki?
    Feb 2008
    Houston
    well....i'm talking about many many decibels. I needed an SDD...maybe he wont, but as he asked about low frequencies, i'm just sayin', this CAN be a problem. it was for me. and your right. well does mean well....not half assed..... don't let them slide out, or wiggle, unless you want problems.
  1. Question - Those with sound systems (subs) and computers....
    By animus in forum General Hardware Discussion
    Last Post: 05-19-2003, 10:07 PM
