Originally Posted by
OldSpark
Excellent Blu!
But you didn't say that if the air goes too fast, the heatsink does not have time to cool down.... LOL!
:sorry: I couldn't resist.... Many car buffs claim that is the reason cars overheat when high-revving or after removing the thermostat (removing thermostats on some engines makes them run cooler; others hotter).
IE - the water/coolant isn't in the radiator long enough to cool down, or it travels too fast to get rid of its heat! (Yet surprisingly it's in the engine long or slow enough to pick it up!)
I'd try to explain the non-time dependent relationship and the difference between heat transfer and temperature - eg, if travelling three times as fast it may only fall by half the normal temp drop, but it does that 3x faster - ie, more heat transferred per unit time.
And lots of other analogies....
For those that don't know why....
If fluid moves very fast, it can jetstream or streamline (pick a narrower path through the radiator etc).
Also if too fast, the driving blade (waterpump) can cavitate and hence reduce flow.
Removing the thermostat reduces restriction (back-pressure) and causes increased flow rate - unless cavitation occurs. (And increase flow may jetstream.)
Hence hi-revving engines may need to reduce waterpump speeds.
Removing thermostats depends on normal versus cavitation speeds etc.
Jetstreaming depends on the layout (water paths).
And on a related note - cavitation reduces input power. EG - a fan blockage causes the fan to speed up and its current drop.
That's the opposite to what many failed alarm systems seem to think!
Blu - is my novice explanation(s) ok?
And I assume this is valid for low speeds - too high and friction causes heating, but we are talking speeds way below that (ie, subsonic?)?
I thank you for your q formula which is devoid of time & speed (other than q being a "rate", but that's not "speed").
I must use it next time....
