Results 1 to 8 of 8
Thread: Dust problem
    May 2010
    Dust problem
    Hi,
    I've been running a PC in the boot of my car for about a month now. It's been randomly rebooting recently and after taking the case off I have found a LOT of dust inside. Every time I go over a bump, dust must get kicked up out of the carpet and sucked into the case. Its a tower case with two fans sucking air in at the front and two exhaust fans on the back. Does anyone know of a good air filter system that still keeps the PC running nice and cool? Thank you in advance.
    Jan 2008
    thin strips of foam? or maybe some hacked up home-air filters?
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    maybe a pollen filter for the cars A/C could be taped over the fans sucking air in...
    but the case has to be taped up everywhere else so that the dust/air are forced to go via the filter first
    just a quick thought
    Blessed are the "cracked" for it is they who let in the light.
    Raw Wave
    Nov 2009
    And don't forget to regularly clean the filter.
    Else rig up some thermal warning, or a "low flow" warning (an air flap is probably the easiest).
    Mar 2010
    Detail your car more often?
    Mod - all of it. SapporoGuy's Avatar
    Aug 2009
    SonyLand
    close the trunk?
    How about surgical masks? High pollen filter, disposable and what not.
    Oct 2008
    Odense, Denmark
    the funny one.... mount the car pc on roof, the high airflow will keep dust away and cool the pc... not sure how performance will be in rain thou
    May 2010
    Quote Originally Posted by boelle View Post
    Haha, that's one solution to the problem but not one that I will be trying out.
    Looks like I will be creating an improvised filter solution with some of the suggestions here. Thanks.
  1. Fighting against dust?
    By xbtsw in forum General Hardware Discussion
    Last Post: 05-05-2010, 03:08 AM
  2. Replies: 13
    Last Post: 06-02-2009, 09:42 PM
  3. Replies: 0
    Last Post: 05-31-2006, 10:19 PM
  4. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-30-2006, 11:09 PM
  5. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 07:41 PM
