Results 1 to 10 of 14
Thread: Protecting from EM Radiation
    Dec 2011
    Whenever I drive in specific places (e.g. near an army radio tower on the way to work) the voltage to my Car PC spikes and the M4 ATX trips the shut down sequence. I was wondering how everyone else deals with this?
    I've looked into voltage regulators I could put right before the PSU but I can only find 12V ones at around 1A - I need about 20A. Is there anything I should be doing extra to shield my power cables to prevent voltage spikes?
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    What are your computer specs? needing 20amp seems very high to me. All of my car pc's/test boxes very rarely go over 4 amps under full load. SNO
    Dec 2011
    Quote Originally Posted by SNOtwistR View Post
    Sorry I just took that figure from the PSU (it's a 250W PSU), 7-8A is probably closer to right but most of the 12V voltage regulators I've seen are 1A.
    Specs are:
    Intel DH77DF
    Core i3 3220T
    40GB Intel x25-V
    Asus Xonar Essence STX
    + two USB powered LCD screens (1A each @ 5V), a USB charging Wifi modem (900mA @ 5V), potentially two mobile phones at the same rate (900mA @ 5V each).
    Raw Wave
    Nov 2009
    How do you know the input voltage is the problem? (And if so, why not a filter?)
    Isn't it signal injection into the M4 etc? (Especially the M4 - it's a known noise emitter.)
    It's probably a need for shielding which IS th protection from EMR.
    And you'd need a dc-dc converter rather than a regulator, but that too would require shielding.
    Dec 2011
    Quote Originally Posted by OldSpark View Post
    I've tested the input line with a volt meter, it shoots up to 30V in some places which trips the shutdown sequence. I've managed to block that by having my car PC software make the shutdown button do nothing when travelling at speeds greater than 10km/h but at one specific place the voltage shoots up to about 50V and the system crashes anyway.
    So how do you suggest I shield it? The M4 ATX is in a steel PC case which is grounded to the chassis. If it's emitting noise itself would there be a problem housing it in the same case as the rest of the PC? Do I need to shield the power cables too?
    Nov 2009
    Keswick,On Canada
    Are you blowing bulbs and other components in the car that are not used to that voltage? This makes no sense that kind of voltage spiking without other damage. Waiting for OldSparks reply Just my 2 cents SNO
    May 2012
    Grandville, MI
    There is a thread on this system that deals with RF shielding the very noisy M4-ATX. Not sure where it is but this might be your solution. Also make sure your input wires are large enough. Depending on what else you are powering and how far you are going you are likely going to need 8 gauge power wires.
    You MAY want to look at another power supply for your computer because of the known RF issues with the M4-ATX supply but check out the thread where the posted does a lot of work to remove the RF from the power supply.
    Dec 2011
    The computer seems to be the only think that's being affected. The car's volt meter goes up less than a volt - my thoughts are that the power cable to the computer is picking up the EM radiation like an antenna.
    Quote Originally Posted by redheadedrod View Post
    I used jumper leads (without the clips) for my input wires - they're very thick. Is the M4-ATX really that bad? Are there any good alternatives that have the same features (auto turn on, auto delayed turn off, etc)?
    Raw Wave
    Nov 2009
    Quote Originally Posted by wprime View Post
    I've tested the input line with a volt meter, it shoots up to 30V...
    Which input - 12V to the M4, or from M4 to PC?
    If it's at the M4 input, does it shoot up with the M4 removed or off?
    If it's between the M4 & PC, I'd try another brand of PSU unless some simple bypass capacitors work (eg, 0.1uF or 0.01uF or smaller across the M4 output; maybe input, and signal wires), else as per redheadedrod.
    Also, what type of voltmeter - DMM? Is the DMM shielded? AC volts or DC volts?
    Nov 2006
    Rubidoux, CA
    My guess is you've got insufficient current paths between the M4 and the battery. The car battery should shunt any large voltage spikes to the point that it wouldn't be measurable by the M4. If, however, you have a high resistance somewhere in between the M4 and the battery, then you can certainly get some spikes shooting back. After all, a wire without an easy current path is the definition of an antenna. This needs to be sufficient low resistance paths on hot AND ground.
    2000 Ford Expedition Eddie Bauer - Bi-Fuel Gasoline/CNG
    Intel D945GCLF2 w/512MB RAM, CL Audigy w/KxProject, M2-ATX, Lilliput EBY701
  1. protecting my investment
    By jaupro in forum General Hardware Discussion
    Last Post: 05-28-2009, 09:58 AM
  2. Protecting amp hookups?
    By mustanglou in forum Car Audio
    Last Post: 03-26-2007, 01:44 PM
  3. Protecting subwoofers in the trunk
    By psykopyro in forum Car Audio
    Last Post: 09-07-2005, 06:30 AM
  4. Replies: 4
    Last Post: 03-29-2005, 07:18 PM
  5. Protecting the computer
    By BumpNGlow in forum General Hardware Discussion
    Last Post: 03-31-2003, 12:51 AM
