Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: Jetway motherboard just died!!!!
  1. #11
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Thanks chris350.
    The board went back to the supplier the other day.im away for 2 weeks now so im hoping it will arrive home before i get back.
    Wondering what comes first....parts blow or solder melts...short of having high temp solder aparantly solder melts around the 182c mark.
    Im sure a cap or smd diode can withstand 180c+ temps can it cook its own solder and drop free?
  2. #12
    Nov 2011
    Hmm just got a replacement and it seems it wont post either....i now have only the cpu and system speaker installed and it will spin the cpu fan breifly but thats it...no beeps..
    If i remove the cpu the fan will start but still no beeps..psu tested fine...should a bare board beep on startup?
  3. #13
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    what are you using to trigger the start? power button? shorting the 2 pins? ac powered atx power supply? SNO
  4. #14
    May 2012
    Grandville, MI
    Do you have memory installed on the board yet? Sounds like normal activity if no memory is on board. The number of beeps and if they are long or short beeps should tell you what is going on with the board if it ever beeps. Have you tested the CPU on another board? Might have blown the CPU when you toasted the old motherboard.
    Rodney
  5. #15
    Nov 2011
    Sno..im shorting the power button pins while connected to a tested AC power supply. rodney...i dont have another board to teat the cpu...im hoping its o.k.might need to swing past the local pc shop to see what they have
  6. #16
    Nov 2011
    The only way to test a cpu is to fit it to a known working board right...pity its a intel g2 mobile chip...anyone with a open laptop around Adelaide right now?
  7. #17
    Nov 2011
    Also tested fully assembled....ram x1.cpu... msata ssd and ac power supply.
    no post and no beeps
  8. #18
    May 2012
    Grandville, MI
    Starting to sound more and more like a CPU.. And yes you need to use a working motherboard. I haven't bought a mobile CPU but I am of the impression they are the same setup as a normal cpu and should work on a normal motherboard? I know I could have gotten one for my system but seems like they were significantly more expensive or something so I didn't get one.
    Rodney
  9. #19
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Are you using the same power supply board for all tests? Try connecting your home pc power supply to test?
    I always look for a common denominator, and since you dont have another socket g2 chip to test, next best thing is power supply in the voom2 case.
  10. #20
    Nov 2011
    Yep rray same power supply.but its my bench tester psu.ive also tried a few other m2atx's but i had the same issued with that.
    Isnt it pretty hard to cook a cpu?
  1. Powering Jetway 12V motherboard
    By HuMMeR in forum Power Supplies
    Last Post: 08-04-2011, 11:49 PM
  2. Jetway motherboard SQ
    By Jenova in forum Newbie
    Last Post: 04-08-2008, 12:20 AM
  3. Jetway motherboard won't boot
    By jbaruffa in forum General Hardware Discussion
    Last Post: 02-09-2008, 02:19 PM
  4. Motherboard completely died
    By tooby in forum General Hardware Discussion
    Last Post: 10-08-2006, 03:06 PM
  5. My carputer motherboard died on me as I was about to test in car. Buying TUSI-M
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 04-02-2002, 12:03 AM
