Results 21 to 30 of 33
Thread: Jetway motherboard just died!!!!
  1. #21
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    CPU's can run at 65C all day, and I have been building and clocking pc's since the trim pot overclocking days without ever having let the smoke out. They usually just lock up, then cool down, reset BIOS, and reboot.
    On my board I thought it was bad at first, but it turned out I needed both the 20/24 pin plug as well as the 4 pin cpu power plug to get it to POST, but I had always thought that was CPU dependent so was not needed with a 35watt CPU. Turns out I needed both. I assume you used both cables from your supply to MOBO too.
    If I remember you choose a 45 watt CPU? maybe that stock heatsink fan was weak for a 45 watt chip?
  2. #22
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Yep ive got the 45w cpu and i do have the extra 4 pin power plug plugged in.will try another power supply today just incase the 4pin plug is the problem.
    Its possible that the heatsink isnt good enought...but im sure in testing and normal running this rig has only ever been just idleing along..no heat...and its winter here too now
    Need to get these parts checked somwhere locally i think.
  3. #23
    Nov 2011
    Well after a bit of stuffing around with local shops.most were said the new board was dead.so ive sent it back again but complete this time.ram..msata and cpu to make sure i get one back working.
    Back running the atom now.my god its slow!
    Pretty sure ive being spoilt with the i7 boot speeds..looking forward to its return
  4. #24
    Nov 2011
    So i rang mini-box.com.au today and spoke to old mate there..was a pretty good phone call.dude is totally stumped on the cpu/board issue...but its looking like the original board may have toasted the cpu when it croaked.not a great situation but he isnt yet convinced the cpu is dead..also said he has never seen a dead cpu...he is thinking possible late model board incompatabilitys or bios issue...but he is looking into it as the rest of my parts checkout o.k.
    Question...So if the old board did cook my cpu,should a warranty cover any parts that were taken out by the board malfunction?
  5. #25
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Ethically yes, but greedily no.
    Sent from my SCH-I535 using Tapatalk
  6. #26
    Nov 2011
    Verdict is in...cpu is now faulty but the board is o.k.
    Im guessing one took out the other...
    Mini-box.com.au has offered me a i5 replacement and will post back a working carpc with a additional com port daughter board and new heatsink and fan (per my request)
    Sad to see the i7 go but im happy with the service.so glad a shopped from a actual store and not just from ebay that time.
  7. #27
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    An i5 is still a good choice. Is it a 35w or 45w chip?
  8. #28
    Nov 2011
    Not actually sure.all he said was its a laptop pull..im sure dual core will keep me happy as im sure ive read that centrafuse only uses one anyway.should have it back next week now
  9. #29
    Nov 2011
    Its back and working!! Not as fast but its o.k.
    Just mounting it all in a new case and doing a rewire.
    Happy days!!
  10. #30
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    That's good news. Which i5 chip did you get?
  1. Powering Jetway 12V motherboard
    By HuMMeR in forum Power Supplies
    Last Post: 08-04-2011, 11:49 PM
  2. Jetway motherboard SQ
    By Jenova in forum Newbie
    Last Post: 04-08-2008, 12:20 AM
  3. Jetway motherboard won't boot
    By jbaruffa in forum General Hardware Discussion
    Last Post: 02-09-2008, 02:19 PM
  4. Motherboard completely died
    By tooby in forum General Hardware Discussion
    Last Post: 10-08-2006, 03:06 PM
  5. My carputer motherboard died on me as I was about to test in car. Buying TUSI-M
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 04-02-2002, 12:03 AM
