Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: How can I power my car from a standard outlet?
  1. #21
    Constant Bitrate BoyRacer0013's Avatar
    Nov 2011
    Chicago - northwest side - where the corn fields start.
    Quote Originally Posted by nobb View Post
    You can get some relatively compact, switch mode chinese made power supplies that are capable of 20 amps from eBay for about $40 (available in 12V, 15V, 24V and etc). They even have a potentiometer to adjust the voltage slightly by about +/- 10%. That's what I did to my car. I got a 15V 20 amp supply, adjusted the output to 14V, then connected the output with a high current diode (of which you can find in an old ATX power supply) in parallel with the car's electrical system and installed everything neatly near the spare tire compartment in the trunk.
    Bam, now I can run an extension cord to the car whenever I want to work on the carpc or have the music running while Im in the garage.
    Are you talking about something like this?
    How do you have that connected to the car, how do you keep it from over-charging your battery?
    Enter the LOTUS...
    (more info here)
    Pre-build thread
    Planning: ::::::::::::
    Parts: ::::::::::::
    Build: ::::::::::::
    Test: ::::::::::::
    Install: ::::::::::::
    Oh, yeah, and build the car... ::::::::::::
  2. #22
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    That's similar to the one i have but not exactly. It would work though. Just keep the output voltage at 13.5 - 14v and you can simply hook it up in parallel to the car's electrical system. No need to worry about overcharging.
  3. #23
    Nov 2011
    I decided to over-complicate this a little, I wanted to lock out the starter when the car was plugged in, and to require the key to use the computer when the car is plugged in, and automatically disconnect the battery when I plugged the car in. This way I can use this power supply, which is much cheaper, but outputs 12volts. Oh, and I added push-button ignition
    Attached is a rough schematic of the system.
    Attached Files Attached Files
    Enter the LOTUS...
    (more info here)
    Pre-build thread
    Parts: ::::::::::::
    Build: ::::::::::::
    Test: ::::::::::::
  4. #24
    Dec 2011
    This definitely seems over complicated.
    Here is my advice... Find yourself some sort of quick connect cable ends that will handle 15VDC @ 30A, wire the female end up directly the car battery (with a suitable fuse) - and mount it so you can access it easily when you need to plug in the car. Under the hood, perhaps. Wire up the male side to a regular car battery charger (~$100 for a nice one, you can probably find one for $25 on eBay or craigslist).
    Then, when you want to have the computer on, you just plug the charger in. No need to wire anything else differently. And if you're using a battery isolator, wire up the charge wire to the central post (same one as the alternator) so that both batteries are charged when you plug in.
  5. #25
    Nov 2011
    The reason I decided to do it the way listed above (post 23) is because; a) for the reasons listed there, & b) because I couldn't find a battery charger that could output that high a sustained amperage that was in budget. Take a look at the .txt file attached to that post, I know its crude but you should be able to figure out what is going on.
    Enter the LOTUS...
    (more info here)
    Pre-build thread
    Parts: ::::::::::::
    Build: ::::::::::::
    Test: ::::::::::::
  6. #26
    Dec 2011
    I tried looking at the .txt file, but it doesn't seem to have formatting - its just a single line of text for me, and I couldn't get it to line up. A .gif or .jpg might be a bit more helpful.
    I did a quick search and found a 30 amp battery charger for $80 at Amazon. Even this, I think, is overkill. You had said you needed 30 amps - but that is a LOT. 30 amps @ 12v is 360 watts. 360 watts is enough for my entire home entertainment center, including 5.1 surround sound receiver and speakers, desktop computer, and a 40" LCD (total: 250 watts at idle, 300watts when I'm watching a movie) I would guess that most carpc setups use 150 watts at peak (playing a movie with the speakers blasting) - average around 50W when in use, and idle at 25W. Of course I'm making a lot of assumptions here, it's certainly possible for an audio system alone to consume 500W, they're just rare.
    Remember that your charger doesn't need to be providing 100% of the power drain at peak, it only has to provide more than 100% of the average power - in fact, even that isn't necessarily true, as your battery will have some charge in it and you can leave the charger plugged in over night to top it off after you're done.
  7. #27
    Nov 2011
    At the time I posted this thread I was planning on running an OPUS 360, and a midd-low end graphics card. The idea is to be able to run the computer and lights with out any drain on the battery for things like updates, but also at a car show (hence the need to disable the starter). I figured that the computer running at full power playing HD video on at least 3 monitors and all the lights and everything else that would need to be run at a show 30 amps would be adequate. I have since decided to go with a M4-ATX and lower power USB graphics cards, but that is still gonna need a lot of power. Attached is the schematic, this time with Windows formatting instead of UNIX formatting.
    Enter the LOTUS...
    (more info here)
    Pre-build thread
    Parts: ::::::::::::
    Build: ::::::::::::
    Test: ::::::::::::
  8. #28
    Dec 2011
    Damn, that is a lot of power!!!
    I think you're right, with 3 monitors and lights and stuff, you can hit 20 or 30 amps for sure. Also, good call on disabling the starter. It would suck to have somebody try to steal your ride at a show!
  9. #29
    Nov 2011
    Quote Originally Posted by CyberBill View Post
    Yep, and all this in a 40 year old 1500 pound sports car
    Yeah that would really suck, but I'm not expecting to meet very many people who would be capable, let alone willing, to actually get into the car.
    Enter the LOTUS...
    (more info here)
    Pre-build thread
    Parts: ::::::::::::
    Build: ::::::::::::
    Test: ::::::::::::
  1. 2001 Acura MDX constant 12v power outlet.
    By geobag in forum Power Supplies
    Last Post: 08-01-2010, 09:53 PM
  2. extending wires on power inverter outlet
    By tgm4883 in forum Power Supplies
    Last Post: 01-28-2006, 12:09 PM
  3. powering m1-atx dc via power outlet (USA 110V AC)
    By dtran01 in forum Power Supplies
    Last Post: 01-13-2006, 10:27 AM
  4. How to power carPC from AC outlet
    By buurin in forum Newbie
    Last Post: 11-04-2005, 07:45 PM
  5. 300 Watt Dual-outlet power inverter DC to AC
    By TheKurbster in forum Classified Archive
    Last Post: 01-09-2005, 11:08 PM
