Where did yoo get 1.94? I checked his site the other day ans I didn't see any link. (is this only for beta testers? and if so I would like to be one)
Thanatos.
Hi,
when you only enable Frodosupport.. but you do not specify the FrodoDatabase link.. it will only sync the same file over and over again.. getting disconnected everytime at the end of the file...
Thanatos.
1.94 is in fact the beta version..... there is a link on how to sign up to become a beta tester
Got it.
Thanks.
This is because the database open fails, but it still tries to write the entries when it syncs up. If a critical such as this occurs during syncing, then sync is terminated.Originally Posted by strohj
I've changed it to disable FrodoPlayer support if the database is not specified or is not able to be opened for any reason. A log message will be displayed on the client window in this instance.
Thanks, Ric.
EZSync - http://www.richmet.com/ezsync
Can you make it look in the default folder for frodoplayer to find the database.. and if it doesnt find it then.. it will ask you to point to it?
that way you have all bases covered..
Sure, I will look into it.Originally Posted by strohj
I have been using EZSync with frodoplayer support to sync up all the changes in my songs.. BUT after finishing the Sync.. if I close frodoplayer and open it back up I dont see any changes to the database...
when I update the database in frodoplayer itself.. It will update the changes in the files...
I am using Frodo 1.10
so I dont know if this is a issue with EZSync.. or a problem with Frodo 1.10...
I only ever tested it with FP 1.09, in which it worked fine. TBH I was considering removing the FP support because I can't guarantee something won't change in future FP versions (which is probably what has happened here). I have to say I don't bother to use this functionality myself, even though I use FP!Originally Posted by strohj
Ric.
I was just testing it because it was there... in fp 1.10 it is fast enough to sync the database so its not a big issue
