Results 1 to 10 of 12
Thread: my bezel is melting :(
    Feb 2006
    i come out to my car the other day to see this:
    im going to sand it down and maybe do another layer of bondo and then paint it. my question is what should i prime it with so that the paint that goes on the bondo and the paint that goes on the plastic looks the same color. and what would i cover it in when im done so this wont happen in the future?
    Oct 2006
    wow what did you use, elmers glue? I've never seen bondo or any product suitable for making a bezel melt before.
    Anyway...just redo it with a filler that won't melt, shape it up, prime it, and paint it. I'm not quite sure I understand your question...are you asking which primer you should use to make the painted bondo match the existing plastic? I don't think it matters that much, unless you paint really lightly the primer won't show through at all, just pick a paint that matches the color of the plastic.
    Low Bitrate briderx's Avatar
    Mar 2007
    Tacoma, WA
    Ha ha ha.. I am SO SORRY, but that looks funny as hell! It looks like you used raspberry jam as a filler.. MMM.. Jam..
    Anyways, if it's the filler that is melting, I wouldn't just sand it down and repaint, I'd personally redo it.. It's bound to happen again. Can you tell us what you used?? Something we all can avoid and benefit from... Thanks!
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    It's not melting. Filler material is suck. It doesn't stick well to the dask trim and separated/cracked.
    It happen to me too and I have to redo it with better filler and a little more knowledge about the products I learn over the years.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    Quote Originally Posted by briderx View Post
    o man.. that made me laugh out loud... haha..
    mine didnt melt but it cracked..
    FLAC J187's Avatar
    Nov 2004
    Boston
    [IMG][/IMG]
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Jan 2007
    East Central FLA
    I would suggest you read the very first sticky in the fabrication section concerning product choices for bonding to plastic dash parts. In addition to the Dynatron product referenced in the post, you might try a product by Dominion SureSeal - they make a variety of plastic bonding products that range from very flexible to rigid. I have had very good luck with the Rigid flex bonding agent & filler - XRFNTR material. Has a long work time (around a half hour), but slow to dry (12-16 hours). Once dry, it can be sanded, filed, etc. It's what's holding my Xenarc housing to an OEM dash pod made for a nav system. Takes the FLorida sun/heat (black car BTW) with no problems so far.
    Mar 2006
    Colorado, but Canadian!
    oh boy that sucks!
    I say as the others did, don't just sand and repaint, redo.
    THe filler material you used is obviously no good, and it will happen again.
    Did you sand the sides of the plastic a bit to "rough it up" so that the bondo stuck well?
    1.9in x 2.9in -- 47mm x 73mm
    Feb 2006
    i didnt use filler of any kind. thats all light bondo and fiber glass bondo and my bezel! i have no idea how it happened i just thought the bondo melted.
    FLAC J187's Avatar
    Nov 2004
    Boston
    Maybe there was a substance on the bezel like oil or gloss or something? Did you use the right hardener? Enough hardener?
    Please help.
  1. Replies: 302
    Last Post: 03-16-2012, 04:29 PM
  2. Fabricating buttons on a bezel.. need help
    By gps in forum Fabrication
    Last Post: 01-17-2007, 11:24 PM
  3. Replies: 10
    Last Post: 12-18-2006, 08:50 PM
  4. Fiberglassing Gauge Pod in Bezel *pics*
    By jmilin5931 in forum Fabrication
    Last Post: 10-04-2006, 08:04 AM
  5. 2002 Silverado Custom Dash Bezel
    By AZ_Silverado in forum Fabrication
    Last Post: 08-09-2006, 01:46 PM
