I have all the parts to install a 7" LCD in the dash of my 2001 Ford Focus. I have seen quite a few installations (StevieG in particular) and was wondering if I should use the LCD's case to bondo to the dash bezel or if I should remove the screen from the casing and install it directly in the dash.
StevieG removed the screen but he also had the bezel professionally done whereas I will be trying the fabrication myself. It will take a lot more modifying of the dash bezel and relocating the hazard switch if I choose to use the LCD's bezel but if I use the bare screen I will have to figure out a way to hold it in place and still be able to remove it later.
