Results 1 to 5 of 5
Thread: Resin not mixed enough, now what?
    Sep 2006
    I started a fb job yesterday. I didn't mix the resin/hardener enough apparently, so it isn't curing well. I even upped the temps in my garage to around 23 C. Some spots have cured, but most spots are still wet. Would it be possible to mix up another batch with more hardener (thoroughly this time) and put it over what I have already, or should I rip it out and start over again?
    Nov 2004
    South West
    If you have some suitable thinners you can thin down some hardned and stipple it into the wet spots with a stiff brush.
    You will struggle to get it right through though unless you have a vacuum pump and you can bag it up..
    PB 2.0Ghz, 20GB, 512mb, XPpro. 300GB Usb HDD, Griffin pwrmate, m-audio audiophile fw. BU-353 gps. 2x100w sony amps, 1x150w JBL sub amp, MBQuart front components, 6x9 rear, 10" sub. Audiocontrol epcienter, esp2, 3xs. Clifford G5, Finished, fitted, problems
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    wash the old stuff off with acetone and start again is my vote. You will never get it right by trying to add hardener to it now.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Sep 2006
    yeah i ended up ripping it out and starting fresh.
    Newbie clbd39's Avatar
    Jun 2006
    when i'v ehad that problem, assuming it's not too bad, you can just add a few more layers...to soak up the resin and add a bigger hardener portion or you can put a heater up to the fiberglass, i'm not sure what the best solution WOULD have been depending on the situation but that is my 0.02
  1. acrylic resin
    By koisuruusagi in forum Fabrication
    Last Post: 11-06-2005, 03:29 PM
  2. fiberglassing trouble with resin
    By Sillydipstixs18 in forum Fabrication
    Last Post: 06-30-2005, 02:48 PM
  3. disolve resin?
    By 88hondapreludes in forum Fabrication
    Last Post: 05-22-2005, 01:47 PM
  4. Where to get polyester fiberglass resin and ...for cheap....
    By Seabass in forum General Hardware Discussion
    Last Post: 07-26-2003, 09:00 PM
  5. Fiberglass resin questions
    By ddt in forum General MP3Car Discussion
    Last Post: 10-02-2002, 01:07 PM
