hmmmmmmmmm, wonder if you could make a fiber glass mold of your car, then use this to make a clear molded sub box... or would it be no where near strong enough?
This is not my thread, but I thought the how-to was nicely done and has some good information in it. I am not sure how many people want to make clear parts, but it is worth a look.
http://forums.nasioc.com/forums/show....php?t=1236593
Thanks, this is good to know.
{Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
MY INSTALLATION LOG
i don't think the fiberglass resin itself would give enough structural integrity to actually make a subbox out of it... as for other fiberglass parts that aren't load bearing, go for it... but for a subbox i would say no go.
ugh, guess my post didn't go through bleh. i just wrote a long response to that. But working with standard all purpose fiberglass resin, the fiberglass matting adds the strength paired with the resin itself, using JUST a type of resin to itself with no structure i really wouldn't trust it
then again, i honestly have never worked with Casting resin, so i'm not 100% sure how that would work out. I jsut re-read the post and realized it wasn't any type i've ever worked with
i've actually used that exact resin and it's tough, not tough enough to make a box nor is it cost effective but for smaller parts it works great. i recommend using smooth on for your molds since it's so easy to work with then use that same clear resin for your clear part (it's pretty cheap compared to smooth-on's clear resin) you can also buy dye to change the color of your parts.
's
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
^^guess that figures it for usnot possible for a sub enclosure
eh woulda been cool, oh well...
i agree... that would be a very nasty sub box... completely see through... and when you blow your sub, you can get a nice smoky mix in the subbox that you can see
we had this kid come in with his sub one time, completely blown in a MDF box with 1wall plexi, he messed up the install and was like "Is this sub bad?" All you could see was smoke...
