Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 7" 97 eclipse gst install
  1. #11
    Jan 2007
    dundee, il
    Quote Originally Posted by VPrime View Post
    Hey looks like a nice set up so far. I have a talon with a carputer.. I went with a different screen so I had a much easier install.. But yours looks much better I think... But then mine is deeper so I have less glare
    I think a "strip" of tint at the top of the window would help a little with the glare, as our dash is sort of angled.
    edit: Also the 5spd Shifter is still in the way a little. I find it blocks the right side of the screen a little( bottom right mostly) But nothing really annoying. Oh and a short shifter will do nothing. The short throw shifters available for the 95-99 Talon/Eclipse only lower the height half an inch or so. You would need to cut out a bit from the short shifter then re weld it.
    the tint stip would probably help a bit, i hadn't even thought of that, thanks a lot
    good to know about the shifters not being much shorter, but cutting and welding isn't a problem at all.
  2. #12
    Apr 2007
    Hey, just a question, I have the same screen and wanted to know what did you use to cut off the buttons part from the monitor piece? I think I'm going to reroute my buttons else where.
    Thanks, Kadaj
    PS, very clean install, I like it very much.
  3. #13
    Jan 2007
    dundee, il
    Quote Originally Posted by xKadajx View Post
    Thanks, Kadaj
    i used a dremel to cut the bezel, but the actual buttons are mounted on a board that just screws onto the bezel. i just unscrewed the board and it is hanging behind the dash, i planned on unplugging it, but never ended up doing it.
    thanks for all the comments
    david
  4. #14
    Jun 2007
    Fort Campbell, Kentucky, United States
    looking good, keeping an eye on this forum because I am getting ready to start a build myself on a 1997 Eclipse GST
  5. #15
    Vendor - Qube colin's Avatar
    Dec 2006
    So you only used Bondo to hold the screen in place? I havent fabbed mine fully yet, but I know that's a no-no. Aren't you worried about cracking?
  6. #16
    Jun 2005
    chicago, Illinois
    Quote Originally Posted by davidp View Post
    cool, the only issue i have with mine is that the shifter is kinda tall, and gets in the way. after i get the car paid off, that will be fixed by dropping in a 5 speed tho.
    I'd suggest with manual trans shifter, If you go with the B&M shifter 45077 about $150 with the help of a greddy billet shift knob (thread M10 P1.25). It's a good combination to lower the height of the shifter. At least that worked out great for me.
    PROGRESS:
  7. #17
    Dec 2006
    what brand of screen is that?
    I'm looking for a 7 or 8 inch screen for my doors...
  8. #18
    Jan 2007
    dundee, il
    Quote Originally Posted by colin View Post
    no, i epoxied it in place first, then bondoed it. as for the other new posts, i have sold the eclipse and bought a 2008 dodge avenger so the computer will be going in that pretty soon, thanks for the interest and suggestions though.
    david
  1. 97 LT Blazer - Xbox install
    By NizZ8 in forum Show off your project
    Last Post: 10-26-2011, 12:49 AM
  2. now you see it now you dont 97 yukon install
    By FAmonmouth in forum Show off your project
    Last Post: 05-04-2005, 10:43 PM
  3. Not a PC, but a multimedia install in my '97 BMW 328i...
    By JuBu in forum Show off your project
    Last Post: 12-09-2004, 06:28 AM
  4. Infiniti G35, 7" Xenarc Install, How-To Doc
    By god_of_cpu in forum LCD/Display
    Last Post: 02-20-2004, 03:03 PM
  5. Taking apart 7" TFT VGA monitor for custom install?
    By afr0puff in forum LCD/Display
    Last Post: 12-18-2003, 02:50 PM
