Results 1 to 10 of 18
Thread: 7" 97 eclipse gst install
    Jan 2007
    dundee, il
    hi all, i finally decided to start building after i got my opus 250, got the bezel done, and now i'm finalizing the case design.
    here is the monitor bezel being made:
    monitor in one piece:
    this car was made to have a monitor put in it:
    cut the monitor bezel:
    cut it a bit too much, oh well:
    layer 1 of bondo:
    after a bunch of sanding, it was time for layer 2:
    a bunch more sanding, and then layer 3:
    Jan 2007
    dundee, il
    finally ready for some primer:
    i really started to notice imperfections now:
    after spraying the primer, i started forgetting to take pics, but the process was spray, let dry, wetsand, spray more, wetsand more and so on.
    finally sprayed some paint :
    i used a rustoleum textured paint:
    very happy with the ending:
    and installed and running lsx void:
    system specs are :
    HARDWARE:
    unknown mobo
    via c3 nehemiah 1ghz cpu
    256mb ddr
    dynex el cheapo 5.1 sound card (after frying 2 SB audigy SE's )
    eonon 7" vga touchscreen (very nice )
    western digital 80gb 3.5" hd
    western digital 160gb usb external 3.5" drive
    and to power it all, and opus 250w dc-dc
    SOFTWARE:
    nlited xp pro sp2
    RoadRunner
    iguidance 3.0.1
    i will get pics of the case as i build it, but time is hard to come by as i work about 65-70 hours per week.
    looking forward to hearing any comments
    david
    Apr 2007
    looks good! does the glare bother you at all?
    Jan 2007
    dundee, il
    yea, the glare is pretty nasty, but im planning on tinting my windows with probably 5% tint, so the glare issue will be gone (i hope)
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by davidp View Post
    dont count on it unless youre doin the windsheild as well
    Live mp3Car Facebook Chat
    Jan 2007
    dundee, il
    Quote Originally Posted by Sonicxtacy02 View Post
    lol, i don't think ill be tinting the windshield, if i do it will be with the lightest tint i can find, 5% tint would be nearly impossible to see through at night
    on the note of the case, the place i was originally going to mount it (just to the right of the gas pedal, in front of the center console) is going to be too small, does anyone have any suggestions for a good place to mount it so it cant be seen, id rather not have it in the trunk, and my amps are under the seats, any ideas?
    thanks,
    david
    Jan 2007
    dundee, il
    Quote Originally Posted by Charles1 View Post
    nice I am working on mine as well but I am going to retrofit the $130 wrx double din kit on there. See how it turns out
    cool, the only issue i have with mine is that the shifter is kinda tall, and gets in the way. after i get the car paid off, that will be fixed by dropping in a 5 speed tho.
    one tip, try to get the screen angled to face you better than mine does, i wish i did, then the glare wouldn't be as bad.
    Feb 2006
    Ontario Canada
    Hey looks like a nice set up so far. I have a talon with a carputer.. I went with a different screen so I had a much easier install.. But yours looks much better I think... But then mine is deeper so I have less glare
    I think a "strip" of tint at the top of the window would help a little with the glare, as our dash is sort of angled.
    edit: Also the 5spd Shifter is still in the way a little. I find it blocks the right side of the screen a little( bottom right mostly) But nothing really annoying. Oh and a short shifter will do nothing. The short throw shifters available for the 95-99 Talon/Eclipse only lower the height half an inch or so. You would need to cut out a bit from the short shifter then re weld it.
  1. 97 LT Blazer - Xbox install
    By NizZ8 in forum Show off your project
    Last Post: 10-25-2011, 11:49 PM
  2. now you see it now you dont 97 yukon install
    By FAmonmouth in forum Show off your project
    Last Post: 05-04-2005, 09:43 PM
  3. Not a PC, but a multimedia install in my '97 BMW 328i...
    By JuBu in forum Show off your project
    Last Post: 12-09-2004, 05:28 AM
  4. Infiniti G35, 7" Xenarc Install, How-To Doc
    By god_of_cpu in forum LCD/Display
    Last Post: 02-20-2004, 02:03 PM
  5. Taking apart 7" TFT VGA monitor for custom install?
    By afr0puff in forum LCD/Display
    Last Post: 12-18-2003, 01:50 PM
