Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: 2004 Honda Civic Si Install
    Newbie Jakiii's Avatar
    Oct 2006
    Los Angeles, CA
    2004 Honda Civic Si Screen Bezel - CAD Part
    I just finished this bezel for my Civic. I created 3D data in Alias StudioTools, then output an SLA part. I made a mold of that SLA part and cast the final piece in resin, then painted. Here are photos of the finished piece as well as screenshots of the data.
    Elsewhere
    Very nice.
    How about the Wiki?
    Feb 2006
    Vancouver, BC
    wow. professional. Could you describe your fabrication process a bit more? What is an SLA? These are all tools you have yourself or did you get an outside company to do it? Any details you can provide would be appreciated. I would love to find a place that could design and fabricate a bezel for me. Mine is currently cut out of ABS and looks like ***,
    Oct 2004
    NY
    wow, that's some technique you have there, sure beats the bondo & sanding deal
    I'd think that'd be way to much to do for only one piece, but man, I wish I had that kind of stuff available.... more info on it would be great! looks 110% perfect..., I'm guessing modeling stuff like this is your profession?
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    rapid prototyping cost $5/in^3 when i was in school.... that's why i didn't do much of it.... but i'll be damned if that's not the way to make patterns. Good work man!
    Oct 2006
    Los Angeles, CA
    I'm an industrial designer so I have some practice making parts. Rapid prototyping is basically 3D output of a computer model, like an inkjet printer that works in the third dimension. It's not cheap to make something this way, especially if you're only making one of them, but I have resources at work I can call upon. The skill is knowing how to model parts in the computer, but there is a fair amount of old world technique behind that paint, Bondo, sanding, etc.
    Feb 2007
    Looks very very nice but that's not a US version of the 2004 Civic SI is it. I have a 2004 Civic GX and the center console is a quite different.
    Oct 2006
    Los Angeles, CA
    Quote Originally Posted by guizai View Post
    GUIZAI,
    SLA is an acronym for stereo Stereolithography. Wiki it and you'll get a better description than I can offer. The process is this:
    1) Get your hands on the factory mass-production data (computer model) of the center panel in your vehicle.
    2) Spend a few years becoming proficient in a CAD surfacing software such as Catia, Alias, 3D StudioMax, Rhino, etc.
    3) Model your bezel in the computer. Give yourself a .5mm gap between your part and the center panel, make nice highlights, nice fillets, and create backside to you part that matches the screen you're using. In my case I measured screw bosses and stoppers from the Lilliput housing my screen came out of.
    4) Output your model in 3D using SLA or FDM or CNC process. Depending on your material this could be your finished part. In my case the material would warp in the sun. So proceed to step 5)
    5) Dry-fit your part into your vehicle, make any necessary changes. Finish out your RP (rapid prototype) part with primer to 600 grit sandpaper. The A-surface of this part should be ready to paint, but you will not paint it. Proceed to step 6.
    6) Gain access to a casting shop that has RTV Silicone and a nice vacuum chamber. You should apprentice in this shop for a few months because molds are tricky. Make a silicone mold of your RP part paying special attention to the A-surface which you sanded in step 5. The silicone will pick up whatever resolution you sanded to.
    7) Pour polyester resin into your mold to produce the finished part.
    8) Pour another part because you got too many air bubbles in the first one.
    9) Repeat step 8 until you get a good part. Also, go back to step 6 and put on your respirator and gloves.
    10) paint and install. If you made a nice mold and resin part, there will be no sanding required. Every part you pour from the mold will be ready for paint. Or you can cast a colored part, or a clear part, or a part with sparkle glitter if that's your thing.
    I guess I should have taken photos along the way...
    Oct 2006
    Los Angeles, CA
    Quote Originally Posted by N6BER View Post
    It is a US civic. My center panel is identical to yours but the Si has the lower shifter panel where yours has a switch panel and console. As far as I know this center panel is common to all EP civics (2001-2005).
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    That is one freaking awsome work.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. AutoPage 860 + 2000 Honda Civic Wiring diagram Help!
    By pcmofo in forum Hardware Development
    Last Post: 01-14-2007, 07:19 PM
  2. need help 2004 honda civic deck swap
    By timrock in forum Car Audio
    Last Post: 08-28-2006, 11:03 PM
  3. Replies: 2
    Last Post: 07-11-2006, 10:50 PM
  4. 93 Honda Civic Dvd/Mp3/Lcd Install
    By civicduties in forum Show off your project
    Last Post: 01-17-2004, 04:11 PM
  5. install on a 95 honda civic
    By schrodos in forum General MP3Car Discussion
    Last Post: 11-21-2000, 05:43 AM
