Results 11 to 20 of 23
Thread: 98 4runner dash fab, a/c relocation
  1. #11
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    so heres my solution:
    i purchased an identical control unit but with the cables attached, i will splice the cables together (got it all worked out in my head...)
    so now that i have that crisis averted, time for some cutting!!! pictures to come!
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
  2. #12
    Jun 2005
    i have pictures!!! here is what ive gotten done so far:
    i cut out the bottom to recieve the ac controls, something ill have to work on when they get here. the screen is held in at the top and via those wings on each side. im unsure how im going to fill up all that voided space, but im thinking carefully crafted pieces of abs plastic, all epoxied together to provide structure, then maybe fiberglass over that to smooth everything out.
    any bright ideas, things i might have forgot, etc? it helps to know now before i get too deep in. thanks guys.
    Pictures
  3. #13
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Sean, go to any supermarket, food4less, ralph, vons .... and buy yourself a favorite popcicle. Eat the crap out of it and save the stick. Use it to fill the gap. If you don't like popcicle, just go to any craft store (Michael?) and buy some balsa wood. Other option is paint stirring stick from Homedepot or Lowes.
    I use balsa wood on 2 of my installation. Look at my recent Supra fab.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  4. #14
    Jun 2005
    well luckily i have tons of plastic left over from what i cut out, so im cutting and using that to fill in. this weekend ill be able to pick up my sheet of abs from home and start using that to create the front.
    Pictures
  5. #15
    Jun 2005
    im not sure my plastic epoxy is holding...
    i did some research on my plastic type >PPE+PS< and i think it should work, but when i picked up the piece today i heard a crack.
    anything else i should try?
    Pictures
  6. #16
    Aug 2005
    I've messed with my bezel trying to do something less ambitious and I had no luck. The good news is that they come pretty cheap on ebay if you need several iterations. I still have one of my cut up ones if you ever need an extra. Be sure to do the cup-holder mod since you'll lose the heinous cup holders:
    http://www.4runners.org/writeups/cupholder/index.html
    Good Luck
    -Ted
  7. #17
    Jun 2005
    i know of the cupholder mod, and i know the guy who wrote that.. lol.
    i use the rear ones anyway. when i offroad i have a camel bak strapped to my seat anyway. im working on a new center console to be started after this is completed...
    so i got alot accomplished, but no pics of the process. i filled in spots with abs, got the shape with expanding foam via a "great stuff" can, bondo over that, its going to crack on the edges, but i have a pretty good solution for that that will come in next week. so stay tuned!
    now to the pics:
    i ran out of daylight, hence the rough appearance. im doing a road test with it tomorrow to make sure everything works and nothing falls apart.
    Pictures
  8. #18
    Jun 2005
    any ideas on how to mount my ac controls in that hole below the 1 din slot i created? im thinkin of something like a din sleeve that it fits down into and locks in. and then mount that to the metal support panels in the dash.
    any ideas?
    Pictures
  9. #19
    Jun 2005
    ok so try number one on the extending the ac controls failed misserably. im having a hard time tieing the two metal rods together, and the set screws im using to hold the plastic sheeting in place end up crushing it and holding the rod in it.
    Pictures
  10. #20
    Jun 2005
    The AC controls have been relocated, what a pain in the ***!!! anyway, they are done and in and it works great. now all is left is mounting it to the dash (kinda just hanging in there right now) and fabbing up the dash bezel which leads me to this...
    its all still very rough, and very soft in spots. im slowly adding, filling voids and cracks, smoothing everything out while letting it get hard, then thursday and friday are reserved for sanding.
    hoping to have it done by saturday for the car meet, but we will see.
    the abs sludge method seems to hold on to the PPE just enough to keep it from cracking, and i will be extending the abs out over the entire surface in hopes that it wont crack.
    Pictures
  1. 98 Altima Woodgrain Dash
    By Untraceable in forum Fabrication
    Last Post: 04-20-2006, 12:24 AM
  2. That 15" screen dash fab again
    By Skuzzle in forum Fabrication
    Last Post: 07-03-2005, 07:24 PM
  3. 2001 Volvo S60 Dash Fab Pictures
    By jcdillin in forum Worklogs
    Last Post: 04-25-2005, 11:17 AM
  4. New Dash Bezel Fab Problem
    By legend5761 in forum Fabrication
    Last Post: 11-12-2004, 01:32 PM
  5. Suggested LCD to fit in the dash of a 98 civic?
    By zovirl in forum LCD/Display
    Last Post: 08-13-2001, 11:18 PM
