Results 1 to 5 of 5
Thread: Mac Mini + enclosure + lcd + double din bezel = indash carPC?
    Sep 2005
    Hi all,
    Quick question - has anyone done the measurements to determine if the following would work?
    Make a simple enclosure normal double din size. stick a mac mini in it, and mount an LCD screen to the front with the bottom hinged in such a way that you could swing the LCD down to insert a DVD/CD into the Mac Mini or back up for normal operation? And use a factory double din bezel to make it look good? It seems to me if the mini fits, and the mounting area is deep enough, that this could be the easiest way to make a clean all-in-dash PC work. Thoughts?
    Vj99
    Elsewhere
    It sountds like a good plan, I guess. It's not going to look very clean, IMHO.
    As you mentioned, depth is an issue. I've helped with a MAc Mini install in the pocket of a Scion xB and the Mac Mini sticks out just a bit, mainly because of the cables that stick out the back when it's all connected.
    How about the Wiki?
    Sep 2005
    I was afraid of that....I am going to be working with what may be larger space - an SUV, and my Mini comes in tomorrow.....
    Anyone ever seen a right-angle VGA connector?
    Sep 2005
    I also thought that instead of the screen hinged on the bottom, a double din enclosure may also be big enough for a Mac Mini and one of those single DIN popup screens below it.....if I have the depth it might just work.....
    Newbie nano's Avatar
    May 2007
    Guadalajara , Mx
    hi, i spend this morning triying to make that same idea work , and it did kinda, i got the dimmensions from this other project for a 05-06 mustang
    http://www.mp3car.com/vbulletin/fabr...-indash-9.html
    and made a wood box , after that i made a LCD housing box that fits inside the other one with factory bezel in front and made the whole lcd swing
    inside the upper part of the housing , leaving space in the botton for a
    mac mini i just need to see if it will fit inside my dash
    if you want some pics let me know this thing i did its just a proto to see
    if it will work and looks like it does , me so happy now.
  1. Mac Mini questions, possible FAQ
    By metalac in forum MacCar
    Last Post: 09-11-2006, 10:37 AM
  2. Double Din Kit for LCD Mount?
    By Plinkey in forum LCD/Display
    Last Post: 07-13-2004, 11:41 PM
  3. double DIN LCD screen
    By nadir_s in forum LCD/Display
    Last Post: 01-03-2004, 10:21 PM
  4. LCD into double DIN
    By groovespacer in forum LCD/Display
    Last Post: 09-25-2003, 09:02 AM
  5. LCD size for double DIN ???
    By infinitiqx4 in forum LCD/Display
    Last Post: 04-14-2002, 09:28 PM
