Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 50
Thread: BMW E36 Climate Control and Screen Fitting
  1. #11
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Going to 'dump' another PM in here as it relates to similar subject and should available to others.
    Quote Originally Posted by amk136
    hi there,
    first of, beautiful install, it looks factory and thats the look im going for.
    i was wondering if i could trouble you for some help.
    I have got to the point where the headunit is out and the climate control unit has been moved down. What i am having trouble with is removing that damn factory bracket (the black plastic thing) that held the HU and CC in place. I have a 99 323i convertible, dash looks pretty much same as yours.
    Any advise on how to get that thing out of their or even pointing me to the right thread would certainly be helpful.
    thanks,
    Amit K
    OK, that thing is bit of a bugger to play with.
    Basically there are four philips screws behind it holding it in place round the back, plus two which hold it into the airvent
    First of all remove the two screws that screw it to the air vent above.
    there are now two screws to each side of it.
    If you look at the pics of one taken out you will get an idea maybe.
    http://www.en4cer.co.uk/Tutorial.htm
    these are some photos which will be the base of a tutorial I am putting together.
    You should notice the extra pieces down the sides which have the screw holes. You will need a small stubby philips head screw driver.
    It will probably be best to remove the OBC and the sunglass holder so you can reach up and behind.
    Also have some plasters/bandaid ready coz you are more than likely going to scuff your fingers/back of hand.
    You may also find in necessary to break the middle horizontal section, this is not really a problem as you will propably need to remove it anyway to fit the screen on later.
  2. #12
    Jun 2005
    Houston
    i just hat to wait for the two weeks for the bezel to come in
  3. #13
    Apr 2007
    London, UK
    Enforcer,
    thanks for the info. Unfortunately I have been told I need to wait for 4-5 weeks for the screen and bezel ordered from the mp3car store. Simply because the screen is on backorder. As soon as it arrives I will get cracking and post some pics.
    again, thanks for the guide.
    Amit K
  4. #14
  5. #15
    Apr 2007
    London, UK
    Its an E36. I'm getting mp3car's Sunlight readable monitor, based on the Lilliput 619. Although we dont get that much sunlight in London, there are the odd days :-).
    Amit K
  6. #16
  7. #17
    Apr 2007
    London, UK
    No problem, Car PC should be in the car by July, full audio set up wont happen until later on this year (financial constraints), this is, I have to say, a hobby with no financial bounds, lol.
    Amit K
  8. #18
  9. #19
    Nov 2005
    FL
    what did you do with the ir eye for the remote control?
    Is it still usable?
    CLICK ME FOR BMW CARPUTERS
    95 Avus M3
    Mods: ;-)
    Carputer: Lilliput 619, GPS= LT-20 Receiver, IGuidance 3 & Streets & Atlas 2K6, RR Front End, Removable Dell Inspiron Laptop, More to come........
  10. #20
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I have left the button board disconnected for the moment. But will look into imcorporating sometime in the future (although I haven't had it connected since . . . . . ever ).
  1. FAQ: Touchscreens explained
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 07-21-2008, 11:10 AM
  2. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 04:19 PM
  3. control climate control via PC?
    By GuessWhosBack in forum General MP3Car Discussion
    Last Post: 09-15-2006, 11:54 AM
  4. Lexus climate control screen help
    By skippy911 in forum Hardware Development
    Last Post: 06-05-2006, 08:10 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
