Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
Thread: BMW E36 Climate Control and Screen Fitting
  1. #21
    Nov 2005
    FL
    so your monitor is set to auto on and is always on when the car is on?
    CLICK ME FOR BMW CARPUTERS
    95 Avus M3
    Mods: ;-)
    Carputer: Lilliput 619, GPS= LT-20 Receiver, IGuidance 3 & Streets & Atlas 2K6, RR Front End, Removable Dell Inspiron Laptop, More to come........
  2. #22
  3. #23
    Jun 2005
    Houston
    does anyone else make the bezel. i dont want to wait 4-5 weeks for one
  4. #24
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Not at the moment.
    You could try a local ICE specialist, they maybe able to make you one up.
  5. #25
    Jun 2005
    Houston
    any body designed a retrofit for the climat control so so it removes the rounded bottoms?
  6. #26
    Jul 2007
    CANT FIT THE AC (Climate Control) IN
    Im new here & have been reading & looking at the photos Enforcers carputer.
    I have had a bezel made for me by Mybimmer.net & am now in the process of relocating to CC down to the sunglasses area. I'm having trouble fitting it in.
    1. It seems to be a fraction to wide for the gap, do you have to file down the inner lip of the centre console?
    2. The CC is too deep & fouls against the large reinforcement bar behind.
    How do you get around these problems above?
    Is there anything else i need to know or do to fit the CC down below the OBC?
    If anyone could help it would be most appreciated.
    Many Thanks
  7. #27
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    1. No, leave the console as it is, you need to trim the sides of the facia. Just cut the crinkly bits on the side upto the front (don't cut the front) and go back as fat as the raised screw holes.(that will give something to hook to the console sides and help it stay in place.
    2. You need to trim the plastic back and remove the vertical board and tuck that down under where the switches go. You must leave enough of the back for the fan to fit onto though.
    I will try and get photos of what I have done next time I take the centre part out, but it won't be until Sept at the earliest.
  8. #28
    Jul 2007
    Is the backing easy to cut?
    Is it a hack saw job or will a sharp stanely knife do it?
    When you say cut the crickly bits on the facia of the CC you mean only up those bits off? Or do you cut further as in triming the whole edge off?
    Is there any chance of breaking to CC?
    Does you CC stick out at all or is it sitting inline with the OBC above?
    Cheers for your help but i think i might need somoe more!!
    Want to get this looking as OEM as possible
  9. #29
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I used a junior hacksaw for the back and a sharp stanley knife for the facia.
    Make sure you take the PCB boards out before cutting. Be careful with the ribbon cables.
    In the picture the red area is what is cut, but only cut back to the screw posts (plastic).
    You will notice that the red mark does not go all the way to the front, you need to leave the very front intact.
    And yes it is flush.
    Here is a link to some pictures (it's how to fix a CC) but it will help you in dismantling it.
    http://www.macadamizer.com/bmwfix.html
  10. #30
    Jul 2007
    Right its all making alot more sence now.
    Where you say only cut to the screw post do you mean stop there so cut between to two screw posts? so you take off (if i counted right from the photo) 8 of the crinkles. Ie from the top (flat bit) down to the bottom (curved bit) Then leave the crinkles that start on the curve of CC at the bottom.
    am i right for the bits to cut in the photo i attached?
  1. FAQ: Touchscreens explained
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 07-21-2008, 10:10 AM
  2. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 03:19 PM
  3. control climate control via PC?
    By GuessWhosBack in forum General MP3Car Discussion
    Last Post: 09-15-2006, 10:54 AM
  4. Lexus climate control screen help
    By skippy911 in forum Hardware Development
    Last Post: 06-05-2006, 07:10 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
