Page 5 of 5 FirstFirst 12345
Results 41 to 50 of 50
Thread: BMW E36 Climate Control and Screen Fitting
  1. #41
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The information about the depth of the Climate Control is in this thread, you need to cut the plastic.
  2. #42
    Oct 2008
    i just didnt understand it ... should i cut the plastic of the CC.. or the plastic of the car behind the cc ??
  3. #43
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You cut the CC plastic, posts #27 to #33 show where to cut.
    I would recommend you get a spare one is case you mess up, as the car will run on full heater without the CC in it.
    And make sure you only cut the plastic when you have taken the circuit boards out.
  4. #44
    Oct 2008
    okai i will try to do it carefully i just didnt get cutting number two is it the vertical back of the CC because in the post the red line is in the middle of the CC. and what do u mean by.
    tuck that down under the switches ..
    and do i have to take the circuit bored out ??
    thank you sir you are the expert it will be usefull if you could post some diagrams .
    I live in Egypt and many are waiting for me to do it so if i did it wrong i will be screwed .
  5. #45
    Oct 2008
    i got number 1 clear but number 2 still not !!! can any 1 explain and iwill do it and post photos !!! (sacrificing my self)
    i need diagram or anything about trimming the CC to accommodate the depth. do i cut anything ?
  6. #46
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Next time I have reason to take my CC out, I will take photos, but don't hold your breath as it is in and working and I don't want to tempt fate by taking it all out again.
  7. #47
    Oct 2008
    that wiould be kind of you i started trimming and will b posting photos. i just want to get the second point clear : whaen u said
    "2. You need to trim the plastic back and remove the vertical board and tuck that down under where the switches go. You must leave enough of the back for the fan to fit onto though."
    1- the vertical board do u mean the one has the buttons on the front.
    2what switches do u mean
    3- tuck what down.
    Thank you and forgive my annoyance
  8. #48
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    oops, meant horizontal one, ie not the one with the buttons on the front.
    in between the sunglasses holder and the gear stick there is a row of switches, normally things like ASC and Heated seats switches sit there, you may just have a row of blanking panels.
    You tuck the PCB that was horizontal.
  9. #49
    Oct 2008
    oooooh i got it right now i already started cutting i will past some photos when i finish..
    but when i remove the blastic there is the green board (circuit) inside it.
    should i throw the blastic away and keep the circuit naked
    cause if i bind it down i will not be able to use the screw any more ???
  10. #50
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well at present my board is naked, but I did plan on putting a case around it, just never got around to it.
  1. FAQ: Touchscreens explained
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 07-21-2008, 10:10 AM
  2. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 03:19 PM
  3. control climate control via PC?
    By GuessWhosBack in forum General MP3Car Discussion
    Last Post: 09-15-2006, 10:54 AM
  4. Lexus climate control screen help
    By skippy911 in forum Hardware Development
    Last Post: 06-05-2006, 07:10 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
