Good work up, but I only have one thing to criticize, the use of fleece...
I am not flaming you or anything, but wanted to state this for newbies to fiberglassing.
expandable polyester like swimsuit material or spandex is much better than fleece for fiberglass work. It is so much easier to make complex curves with, and you can stretch it uber-tight holding it down with CA Glue or staples.
When
applying resin on spandex type material, you do not have to use as much, thus reducing some of the costs involved in enclosure fabrication. Fleece soaks up way too much
resin and gives people a false sense of security because of the thickness and the it is strong as a rock attitude after the resin dries. I have seen too many people crack boxes because they used fleece, then not enough fiberglass cloth for strength.
Yes, we all know that the number of layers of fiberglass cloth laid down gives you the strength to your structure. Fleece just gives too many people a false sence of security. A sub enclosure has to be balls-to-the-wall solid, with enough layers of fiberglass.
I just wanted to make this point so that newbies to fiberglass don't fall under false sense of security. Once again, not to be as a flame, just informational.
