Results 1 to 5 of 5
Thread: gluing foam
    Apr 2007
    St. Louis
    gluing foam
    Folks,
    Door panels in my car have like white foam covered with plastic.
    What do I use to glue to that foam? I need to glue metal braket and need maximum adhesion. Original braket was molded in and fell out..
    Thanks!
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    take a picture of what you're talking about...
    Apr 2007
    St. Louis
    Thats a metal clip that was molded into door cover. You can see it's imprint next to clip. How do I glue it in?
    Jun 2006
    Denver, CO
    try PL construction adhesive. it's a thick, peanut-butter colored adhesive that comes in either a foil tube or a cartridge for a caulking gun... you can get it at lowes or home depot. It has excellent gap filling properties, and air dries in about 24 hours and is completely waterproof.
    this is what it looks like
    Just make sure you get it in exactly the place you want and if possible apply light clamping pressure to squeeze out any excess.
    Wear gloves with this stuff because it will turn your hands black for days. Clean up with mineral spirits before it cures and you should be in good shape.
    Apr 2007
    St. Louis
    Ok, thanks. I will give it a try..
  1. Replies: 43
    Last Post: 05-10-2008, 06:16 AM
  2. sound deadening foam
    By 84RegalRider in forum Car Audio
    Last Post: 07-05-2006, 07:57 PM
  3. Liquid Foam
    By JPuma in forum Fabrication
    Last Post: 08-31-2005, 09:59 PM
  4. Before you use foam to mount your Touch Screen
    By NewTechFool in forum LCD/Display
    Last Post: 03-05-2004, 02:33 PM
  5. Fiberglass over foam?
    By gork in forum General MP3Car Discussion
    Last Post: 08-20-2003, 06:57 AM
