I'm pretty sure you can fit it in your center consel if you remove you head unit and the cig lighter under it.
Hi guys... I'm a newbie and I'm started using a carputer in my Rover 200 MK3. However, the work isn't finished...
My problem is that the touchscreen I have (a lilliput 8.4") is too big to be placed on central tunnel, so... where I can put it?
Just looking for a permanent installation (at the moment, i put the monitor on the air tubs(???))
Sorry for my bad english, and thanks for the help in advance!!!![]()
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
cut the center bar just below the HVAC stuff.
Remove the ashtray, remove teh radio, move the HVAC down to where the ashtray/radio is. Embed the screen where the AC and radio Was.
You could also relocate the buttons on top o the HVAC.
It's what I did to my bezel and I fit a 8.4" screen
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
Installed
