Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Need Help with Enclosure in GX 470
  1. #11
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    possibly the 4runner. (they are the same vehicle right? or is this the land cruiser, i thought that was the LX)
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
  2. #12
    Jun 2007
    The metra kit will help with mounting, but will it solve my problem of having a 9 x 5 opening and and 7 x 4 radio?
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    All metra kits make it so you can install either a single din or a double din radio.
    Jan Bennett
  4. #14
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by giantshark18 View Post
    That is the whole point. Do you even know what a Metra kit is? It takes weird funky shapes and makes them normal din sized.
    1.9in x 2.9in -- 47mm x 73mm
  5. #15
    Jun 2009
    Lexus GX-470 radio kit
    I have the same truck, I just bought a kit on e bay, last time I look this is the i tem # 110396421575. The kit works perfectly and very beautifil, I think it will work with any double din radio. Good luck
    Vinny
  1. Fiberglass and MDF sub enclosure walkthrough
    By monkeyracer in forum Fabrication
    Last Post: 05-19-2008, 03:55 PM
  2. Replies: 2
    Last Post: 10-06-2006, 01:37 PM
  3. Need help with camera enclosure
    By Gayden in forum Input Devices
    Last Post: 08-31-2006, 06:30 PM
  4. slim optical enclosure with internal battery
    By zPilott in forum General Hardware Discussion
    Last Post: 08-23-2004, 07:29 PM
