Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Glove Box Screen
  1. #21
    Variable Bitrate red_parchel's Avatar
    Jul 2006
    Boston, Ma
    he's suggesting that you may have an air filter behind the glove box that should need to be replaced if it gets dirty, it's a maintenance thing, so if you had such a situation, i would suggest making your glove box door still open as it used to, dont fiberglass it shut.
    MobileThree: in car - Zotac Atom/ION - linuxICE 2.0.2
    --worklog--
  2. #22
    Jul 2007
    yea. we were ganna put fiberglass over the door, but still allow it to open. problem solved. thanks guys
  3. #23
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Well, I got to this thead late but would still like to offer my advice. get some wood and build a frame that fits into that section, once it fits in there good with about 1/8'' gap all along, I would take the screen's bezel and use wood dowels or pop sicle sticks to hold the screen in place where you want it, then stretch your fleece over it and resin it. Then the process just follows of adding glass/bondo sand prime paint.
    Also since you want to make it removable, I would suggest using industrial strength velcro, velcoing the back of the frame you made and velcroing the actual metal where the glove box would sit, this way it stays in place well, and will still be removable.
    EDIT; Just read u got your glove box.
  4. #24
    Jul 2007
    ^^^^ acually, GREAT advice, i appreciate it. ive been checking out this thread on the s10 forums
    http://www.s10forum.com/forum/f26/te...nd-two-208071/
    it helps a lot. i dont understand wat u meant tho when u said popsicle sticks, how would those hold it in place? i could make it so the screen is in there forever, but not sure if i want to. thanks guys
    -AD
    any input would be helpful
    **EDIT: just realized that u JUST REALIZED i got a glovebox door. What would u do then with that?? sorry and thanks
  5. #25
    May 2007
    oh, you would glue the bezel of the screen with the popsicle sticks, then you stretch the fleece over everything and resin it, the resin makes the fleece as hard as a rock. I am not sure how much you know about glass, so it is kinda hard to explain things in depth, but with the glove box, that is a cake job, I have done some just like that, but not for a s-10, just cut the glue box and CA glue the bezel in place, sand it all down, bondo, primer, paint.
    hit me up
    exus28 AIM, if you need more help, this has been my profession for a couple years, so i could probably lend u a brain
  6. #26
    Jul 2007
    ^^Thank You
  7. #27
    Jul 2006
    Boston, Ma
    hey i just wanted to thank you for posting that link to the s10 forum, that is exactly what i was in the middle of doing to my blazer (Same dash) .. wish i had found it 2 months ago, but thanks again!
    -red
    --worklog--
  8. #28
    May 2007
    hey sry missed your IM, I added you to my budyd list, catch online
  9. #29
    Jul 2007
    Quote Originally Posted by red_parchel View Post
    -red
    yea man, no prob. someone sent it to me and i was REAL glad to find it. its a little diff. from my project, but helps me get the idea. good luck
    -AD
  10. #30
    Jul 2007
    going to buy supplys SAT. and starting project SUN. ill hopfully have pics to show.thnks
  1. Glove box mounted laptop DVD-ROM using 15 foot IDE cable pics.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 01-08-2004, 01:03 PM
  2. 2000 Chevy Tracker Glove Box PC
    By nijel in forum Show off your project
    Last Post: 11-16-2003, 08:04 PM
  3. Glove Box Case
    By bjm2020 in forum General Hardware Discussion
    Last Post: 06-05-2003, 02:09 PM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
  5. Laptop/LCD screen hookup...
    By UrbanTacticz in forum LCD/Display
    Last Post: 11-28-2001, 05:49 PM
