Results 11 to 20 of 29
Thread: Epoxy Putty: Guidance to Easy Fabrication for Carputers/Bezels *56k Warning*
  1. #11
    Jul 2007
    Great Thread man. u have a talent
  2. #12
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Quote Originally Posted by stealinfool View Post
    Does heat have any affect on it, as far as expansion and contraction? I've had some issues with different materials... they don't like the heat of a hot unattended car (in the FL sun) followed by extreme cold from the A/C.
    Thats is a valid question, up to date (2 years) I have had no problems, I guess this would be due to the expoy becoming one with the plastic and hardening like a rock, but still sandable. I live in Florida as well, so I know what you mean about extreme heat with an unattended car for a while, But like I mentioned above, not cracks or shrinkage.
    Quote Originally Posted by ayetothedea View Post
    Thanks!
  3. #13
    Aug 2007
    Lake Charles, Louisiana
    This seems perfect, I'm fixing to fab up my bezel to accept a 7" screen and planning on usings ABS sheet for big filler and then the putty to fill it all in. I'll post some before/after pics when I get it done or through the progress. This stuff seems less time consuming.
  4. #14
    Jun 2007
    When you say "Then the putty should be sanded with at least 220, then raged, and then so on, heres the final pictures just to give you an idea of how easy it makes it fills." .. what do you mean by "raged"?
  5. #15
    Constant Bitrate Pathos's Avatar
    Jun 2004
    St. Louis Mo.
    This sounds a lot like the "JB Weld" I have used on car repair projects
    before. It is drillable and when mixed right is pretty tough stuff.....stroke
    of genius using it on a bezel wish I had thought of it
    "A rose by any other name is still a flower"
  6. #16
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    he means using a product called rage gold, which is a filler that helps to get the final product really smooth (way better than bondo)
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  7. #17
    Low Bitrate EagleTG's Avatar
    Mar 2002
    Pennsylvania
    Has anyone else gotten a bum tube of this stuff? The one I got was lumpy, and had a bunch of "shards" in it. Made it really tough to work with. I'm thinking of getting another tube at a different store and trying again.
    -Eagle
    Hardware and Software [#####] DONE!
    Fabrication [#####] DONE!
    Installation [#####] 99.314% (I like Pi! The project is never done.)
    --=> My CarPC Project & Link to Worklog :: My Blog/Website/Photo Gallery <=--
  8. #18
    Jul 2005
    That's usually how they are, I got one that was for "plastic repair" and it had plastic shards in it. I assume the ones for steel have steel or something in them.
  9. #19
    May 2007
    The loctite one is perfect, it is carried at lowes, it has no shards in it at all
  10. #20
    Mar 2002
    Pennsylvania
    Quote Originally Posted by Nexson View Post
    Good to know... I appreciate that. I was using QuikSteel Plastic Repair. I'll stay away from that one from now on.
    -Eagle
  1. Replies: 2
    Last Post: 06-09-2005, 10:23 AM
