Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Epoxy Putty: Guidance to Easy Fabrication for Carputers/Bezels *56k Warning*
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Lightbulb Epoxy Putty: Guidance to Easy Fabrication for Carputers/Bezels *56k Warning*
    I would just like to let everyone know about a product I have been using for the past year for small scale projects. I am not sure if anyone has used it before but I have found it as a life saver. it is epoxy putty, loctite puts it out, also others like Quicksteel, there is a few other brands that make it and they are all pretty much the same.
    Anyhow it is a 2 part mix, you tear off a piece and mix it until it is a uniform color, it has about 5 minutes of working time. The thing that is so great about this is it sort of like abs sludge (meaning it fills areas) but without the mess and curing time. Also, small walls can be built with it and it sands very easy. I use it in cases where I have a dash piece and a bezel that I have bonded together with CA Glue and then sand it down, well it would be stupid to bondo over the abs plastic, because bondo doesn't work well over direct abs, and plus it just meant for pinholes, people have a misconception of using it to much as a filler or bonder. This is why the putty is so great, because it bonds very well with plastic. Then once it is fully cured, the bondo applies well to the sanded putty. The putty is great for filling low spots because it hardens like a rock and actually bonds. Also it is only like $4 a tube.
    Here is a few instances to better explain..
    I have a couple of examples to explain 2 different uses for the epoxy
    Here is where I bonded the bezel with the actual piece, once that was sanded down, I moved on
    Now I didn't get pictures of the putty before it was sanded but, it was about 1/8 thick, which isn't much, anyhow, here is how it looks when it is sanded, it takes all the gashes and gaps and fills them in, hard as a rock, yet still sandable.
    Then the putty should be sanded with at least 220, then raged, and then so on, heres the final pictures just to give you an idea of how easy it makes it fills.
    Okay, now here are the half din tvs I use to make before they became discontinued. Anyhow for the longest time I was looking for ways of filling the gap, the screen didn't come with a bezel so I had to hold to the screen. This is what it looks like before I start molding (btw this is the navi piece, application is for non navi cars)
    I then insert the half din, BTW it is fully bracketed to the underside of the cover. (sorry for different pieces being worked on, I pulled pics from different installs)
    Then I tape off the screen and use the putty to "build a wall" I form it to the side of the screen so it takes the shape of the screen, sort of like a fiberglass mold. After 15 minutes you can pull it out.
    After some file sanding, I can get it like this, by the way, the putty bonds wonderfully with the plastic, weird huh?
    Then the rest is just a process to finishing it!
    May 2007
    Feb 2006
    Vancouver, BC
    niiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiice. Sweet work. Thanks for the pic log.
    May 2007
    thanks, just trying to help out a little bit for the community.
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    Great work and right up!
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    May 2007
    thanks!, bump for others to see.
    Jun 2007
    Minnesota
    I've used that stuff before on some other non-car projects. I hadn't thought of it for use like this. It does set fairly fast though, so you just have a few minutes to work with it before it starts to harden, so you'd need to make sure you have the pieces ready to go when you start mixing it. Thanks.
    Dan from Minneapolis
    1999 Volvo V70R
    Jetway J7F2WE2G, USB Creative Soundblaster, RoadRunner, Holux BT GPS, 3M Capacitive Lilliput, etc.
    May 2007
    yup, you gotta pretty much have your idea already of what you want to use it for.
    Newbie maxgtr2000's Avatar
    Jul 2006
    Nice work, I vote for sticky.
    Constant Bitrate stealinfool's Avatar
    Dec 2005
    Orlando
    Does heat have any affect on it, as far as expansion and contraction? I've had some issues with different materials... they don't like the heat of a hot unattended car (in the FL sun) followed by extreme cold from the A/C.
  1. Replies: 2
    Last Post: 06-09-2005, 10:23 AM
