Results 1 to 10 of 16
Thread: Custom Fiberglass Box Clone
    Mar 2007
    This is what i want to do
    This is my Project.
    and these are the specs of my speaker
    I would like to build a list of things i will need to build 1 box, If i like how it sounds i will build a second unit, this will be my first time fiberglassing and its not rocket science but i think i can do it. any help will be apreciated.
    Dec 2006
    hey, if you look in the sticky there is a tutorial on how to do this. it is very helpfully. and tells you what you need.
    Mar 2007
    Quote Originally Posted by kleicl View Post
    Thanks you.
    Mar 2007
    I need help With how much material i need .
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    http://www.mp3car.com/vbulletin/fabr...x-vibe-gt.html
    http://www.mp3car.com/vbulletin/fabr...lkthrough.html
    Fiberglassing Tips?
    There are so many threads that show how it's done.
    You will need all the materials in those threads.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
    Dec 2006
    ill give you some help on what you need. i did a sub box for my car but it had an amp and computer rack. i used
    8.5 sq meters of 450gm choped mat about 9 sq yards.
    20 kg or poly resin the 20 ltr drums.
    500gm or the cat
    paint drop mat
    heap of 70c paint brushes
    gloves
    fleece
    tape
    all this is on websites and they tell you how much you will need.
    i bought a heap of stuff so then the left overs can be used for pc case top and other things.
    hope this helps.
    Mar 2007
    500gm or the cat
    paint drop mat
    gloves
    fleece
    tape
    hope this helps.
    Thank you.
    Mar 2007
    500gm or the cat
    paint drop mat
    gloves
    fleece
    tape
    hope this helps.
    is there like 1 place that i can get this from
    Mar 2007
    500gm or the cat
    paint drop mat
    gloves
    fleece
    tape
    hope this helps.
    which one would be good from here http://www.fiberglasssite.com/servle...ped+Strand+Mat
    May 2007
    Lakehood, CO
    for chopped strand mat, it all depends on the complexity of your shape, the thicker (read heavier) the mat, the harder it is to contour, but you will need less layers to get to the thickness you desire, whereas the thinner (lighter) mat will contour well, but you'll need more to get the thickness.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  1. Custum Fiberglass Work Needed?
    By MKruluts in forum Fabrication
    Last Post: 11-01-2006, 08:18 PM
  2. Just finished Fiberglass sub box & amp rack
    By sporty_drew in forum Fabrication
    Last Post: 09-09-2006, 10:57 AM
  3. Custom Sub Box Prog
    By Harlanc03 in forum Car Audio
    Last Post: 05-20-2005, 07:52 AM
  4. Replies: 5
    Last Post: 05-15-2005, 06:08 PM
  5. Case design for a stowage box.
    By nibix in forum Fabrication
    Last Post: 07-10-2004, 06:12 PM
