Results 1 to 5 of 5
Thread: MacMini Rear Port Adapter PCB?
    Feb 2006
    Melbourne, Australia
    Hello Boyz,
    Mmm....we all know that when it comes to the MAcMini, we probably have the nicest little PC for a Carputer setup - it has opne major flaw though, and it is the rear ports - especially the Video Adapter.
    When the DVI-I Adapter is connected, and you still have to connect the VGA cable, poofff....ther goes the small footprint needed to install this little monster.
    I was wondering if anyone considered doing a PCB, with all connectors to plug into the original ports, and then have one/two/three cables coming out the side of the PCB, or the top or bottom, whichever way is best for your application?
    Basically a flat PCB, all connectors mounted perpendicular to the surface, plugging in to the MacMini rear, this would decrease the needed "depth" required, making for a much cleaner installation into those tight situations?
    If you know of something, please post a linky here, and no, I am not referring to the few attempts at docs that's out there, just a simple PCB with cables coming out for USB/Audio/Video etc.
    Your feedback would be appreciated.
    If something like this doesn't exist, if I design one, anyone willing to buy them?
    Br,
    MrBean
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
    Dec 2008
    Quote Originally Posted by mrbean_phillip View Post
    Why not just get a cable with VGA plug in one end and DVI plug in the other end so you don't need a bulky DVI -> VGA adapter?
    http://clicktronic.net/index.php?pag...mart&Itemid=26
    http://www.av-connection.dk/?PGr=340&ML=835&Language=UK
    Feb 2006
    @ Blues - still to bulky - a 90-deg adapter would be ideal - you can of course fin them nowadays.....sometimes, even an extra 1-2cm is to much....
    May 2005
    Denmark
    Make your own 90-degree adaptor. You just need to know how to solder.
    I've done mine this way
    I've just cut open the plug, removed all the hot glue, carved a hole in the side, re-attached the plug, soldered on new wires and put in new hot glue. Easy.
    // Per.
    Feb 2006
    Thanx Zapro,
    Yep, I made something similar a while back, too easy
  1. Alpine AiNet aux input adapter SOLUTION!!!
    By aydensdad in forum General Hardware Discussion
    Last Post: 08-16-2011, 06:30 AM
  2. serial port to game port adapter wiring
    By asif in forum General Hardware Discussion
    Last Post: 08-17-2006, 05:47 PM
  3. 12V, 5A Regulated Car Adapter
    By Alta in forum Power Supplies
    Last Post: 03-03-2005, 01:02 PM
  4. slim slot dvd rom with wrong adapter, questions
    By mattress in forum General Hardware Discussion
    Last Post: 10-24-2004, 09:51 PM
  5. USB Serial Port Adapter Troubles
    By bLindmOnkey in forum General MP3Car Discussion
    Last Post: 10-14-2004, 12:29 AM
