Page 1 of 5 12345 LastLast
Results 1 to 10 of 48
Thread: Help With rear seat install, lots of pictures
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    Question Help With rear seat install, lots of pictures
    I have a regular mdf box that i've built for my 98 Camaro, but it doesn't seem to be doing it for me. I'd like to make something new, whether it be fiberglass or mdf doesn't matter to me. My current box is 17 inches deep on the bottom, 15 inches deep on the top, 7 inches tall in back, 4 inches tall in front, and 37 inches wide. I'd like to not go too wild and try to follow the interior lines because i want it to look somewhat like stock. the sub will have to be mounted inverted due to space and i like it this way. Pretty much i need to find a way to blend the box to the sides of the car. So heres the pictures and I'm open to ANY ideas. Thanks
    With both Amps
    Here is how close the box is to my t-tops (sorry only had my phone on me)
    1998 Camaro Worklog Starting over, New setup for 2010
    Low Bitrate kazzxtrismus's Avatar
    May 2007
    FG is the only way to do it cheap and quick.
    it will still have a MDF box inside it.
    but the FG will make it blend...etc
    dish it over the side panels and you will lose the 6x9 holes...but put em back into the new box.
    kinda sucky not having the room.
    this idea is under the assumtion you want to keep the OE spot for your T's.
    Mar 2006
    Iowa
    Quote Originally Posted by kazzxtrismus View Post
    i was thinking of fiberglassing up to the edge about 1 inch from the weatherstriping where the side panels kind of bend. But i might just go all the way to the edge. I'm also thinking that i'll keep the subs and amps mounted the same and keep everything on the same plane (not mold up to amps)
    Loosing room is a fair trade for what the car is lol
    The far rear speakers are 4 inchers, but i have absolutly no rear fill And yes I want to keep my OEM spot for my t-tops, that way i can still access the carputers
    Oct 2004
    Sydney, Australia
    If this is only for aesthetics just modify your old box. Take the carpet off, mask up, take your molds on each side (bonding it to the mdf at the same time), trim to where you want it, fleece over, glass and re-carpet. It will give that snug fit look and is a good fg job for a first timer.
    Continued Worklog... Upgrades in progress:
    *15.4" WXGA LED backlight touchscreen upgrade
    *Custom fiberglass dash bezel
    Mar 2006
    Iowa
    Yea i was thinking along those lines Biggy, but i might end up doing a whole rear seat install (idea on last page of my worklog)
    Mar 2006
    Iowa
    Right now i'm looking to make the box look like this and have 2 subs in it.
    then i will make a false floor for my amps. (black outline is where cuts/seams will be)
    It'll hinge open like this ( still working on a hinging setup)
    And the amps will set underneath ( most likely 3). I want to have the "floor" that they are mounted on then motor up a few inches to reveal the entire amps.
    Sorry about the photoshops, best i could do. What do you guys think?
    Oct 2004
    Sydney, Australia
    That sub box is 100% mdf i think, it shouldnt be to hard to make if your good with woodworking. That box is very shallow and is probably the reason why theres only one sub. Two subs will require a larger capacity enclosure to get any real noticeable difference. There could be a ported solution too.
    The floor shouldn't be to hard either, cut up the existing board add some hinges and stops, a floor for the amps, maybe a opening handle and then recarpet.
    Mar 2006
    Iowa
    i can get a little over 3^ft of airspace. (plenty for 2 x's or r's) I'll have to go look at my measurements i took a long time ago. I want everything motorized so no handles I'm having trouble visualizing how i would finish off the false floor where it meets the front seats.
    Mar 2006
    Iowa
    Bottom view
    I want to make it open like this and use a linear actuator to pull the lines on the end down or maybe something else. any idea?
    May 2007
    hinge them then have the linear pull the 2 ends together over a pulley.
    "a small pc of rope over a pully" is the idea im talking about...maybe a pillowblock and shaft with a "lobe" on it.
    why not remove the back seat all together...replace with 1 bucket seat...put an amp and sub on each side of the new bucket??
    to FG that with a basic fabbed box is no harder... just more ribs.
    costs about the same too...and looks waaay hotter!
  1. sub box design question for you pros.
    By scott_fx in forum Car Audio
    Last Post: 08-28-2006, 09:51 PM
  2. need Idea design for new plexy box
    By Iguana2020 in forum Fabrication
    Last Post: 07-30-2006, 02:39 PM
  3. need a box design
    By scottsenia in forum Car Audio
    Last Post: 07-21-2006, 11:34 AM
  4. Crazy Idea
    By isphius in forum Car Audio
    Last Post: 06-22-2006, 08:10 PM
  5. F/S: JL 12w7 Subwoofer with box!!! Pictures inside
    By neema12 in forum Classified Archive
    Last Post: 08-29-2005, 09:45 PM
