Results 1 to 10 of 12
Thread: Help me fit a screen in my dash
    Aug 2007
    Dudley, West Midlands, UK
    Hi all see below pics.
    This is my dash now
    This is what I was thinking
    Do any of you guys have any better ideas ?
    Would it be better to completely redesign this centre area, can I change the current heater controls and the other buttons with custom ones or buttons from another make car ?
    Jul 2007
    Why cant you redesign the entire centre area and pick and choose where you would want the buttons/controls. That being said i like the idea of moving the hazard light/cigarrette lighter down there, but i wouldn't move the heating/cooling controls up. I would move them down, but fabricate it so they would form a V shape, this way the top section (the larger part would fit a screen nicely.
    My purpose in life... to do everything the wifey says too... or atleast thats what she tells me :P
    Aug 2007
    That sounds OK, but I have no experience in dash fabrication and I don't want to mess it up.
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    I don't want to discourage you, but maybe you should lok into having a shop do the modifications for you. That way, if they mess it up, they have to fix it.
    What I would do is remove all the components you want to move, Make a wood or perhaps carboard template, and fool around with that to see what wil fit where.
    Once you have a working "model", you can start fabricating in fiberglass,abs, or whatever medium you feel the most comfortabl ewith and can get the finnish you want.
    I'd have all the components you want ot fit in on hand also. Nothing sucks more than going off manufacturers specs only to find out when you try to install the part, that it has a weird bump or different dimensions than what you have built...........
    Cheers
    BJ
    Leonardo Da Vinci
    Aug 2007
    cheers, how much would something like this cost to have done professionally ?
    May 2007
    Quote Originally Posted by Red_Stafford View Post
    Well, that all depends on your area. Look for a shop that does custom audio installs and give them a ring.
    I woudl think it won't be cheap though. You can spend anywhere from a couple hundred to 5 or 6 hundred bucks on a custom bezel alone.
    Or, you learn to do the custom work yourself. If you go this way, get a couple bezels from a wrecker and experiment a bit to build your skills before cutting up your own car.........
    Leonardo Da Vinci
    Mar 2006
    Colorado, but Canadian!
    Also if you dont want to fabricate and dont want to spend that much to fabricate, there are flipout screens. it looks like you have a 1din slot available. Problem is flip-outs really suck. But there is another option you can use as a backup.
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2007
    Quote Originally Posted by 2k1Toaster View Post
    Why do flip out ones suck, and if they do then the is no other option than to fabricate one into the dash is there ?
    Mar 2006
    Well there are also roof mount, but that is akward.
    Flipouts are no good because:
    Motorized ones fail often and reduce your $400 screen to garbage
    They refuse to work in temperature extremes. Even though the screen can work, the monitor "protects" itself, and refuses to open in extremes
    They wobble. Think about it, there is nothing supporting the screen except for some cheap gears. So when you press it, it will wobble.
    They usually block air vents (in your case it will too)
    They look cheap and non-OEM. More cheezy.
    The list continues as well...
    Sep 2006
    yeah i have a one din flip out (manual) and i regret it... I'm going to sell it at some point and made a bezel for a screen...
  1. FAQ: Touchscreens explained
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 07-21-2008, 11:10 AM
  2. How can I install my screen to the dash ?
    By shinjetko in forum LCD/Display
    Last Post: 04-24-2006, 01:17 PM
  3. Replies: 1
    Last Post: 02-02-2006, 07:48 PM
  4. how to get frodo to fit screen
    By heynicecar in forum FrodoPlayer
    Last Post: 02-13-2005, 07:07 PM
  5. Monitor VGA+Touch Screen USB+ IN DASH!
    By Ferspain in forum LCD/Display
    Last Post: 10-16-2004, 07:26 AM
