Results 1 to 6 of 6
Thread: Fabrication material in India
    Sep 2007
    I have started this thread for my Indian friends.I have seen that fabrication material is easily available in U.S. but its very difficult to even get any information about it in India.Nobody knows or even cares about doing it.
    But i have found it and want to share it with everyone specially people who live in India.
    The material that can be used as a filling (bondo as is known in U.S.) is mseal by pidilite.U can easily get it in any hardware shop,it is mainly used to fix a leaking pipe or leaking tank etc....It comes with a resin base and a hardener.It can also be used on any plastic or metal.
    I personally tried it.I mixed equal portion of the hardener and the resin base, tried it on a plastic piece and let it dry.It says it will be hard in about 30 minutes but it took around 3 hr so that sand paper could be used to smoothen it.
    It cost INR 10 for a 30gms pack.Bigger packs are also available.It can be used to make a customized bezel.Hope someone will soon try it and post it on mp3car forum.
    If anyone finds a better material easily available in India plz let us know.
    May 2006
    Belgium
    i don't know how much a INR is, but why not "import" it? let someone in the US or Europe send it to you?
    that way you can easily use whatever we are using, and maybe it's cheaper...
    Greetz
    Dj NRG
    Sep 2007
    1 US Dollar = Indian Rupee(INR) 40
    It is not possible for everyone to import it.And this material is available easily in India and it is very cheap.
    Will be using it for my car project soon.....
    Variable Bitrate Phatsacks's Avatar
    May 2007
    Springfield, Va
    Sounds like we need to outsource custom bezel fabrication to India!
    Oct 2005
    Mumbai, India
    Go to a decent paint/body shop and ask for polyester putty. It costs less than 200 rupees for 500 gms, cures in around 5 minutes and is ready for sanding in 20 mins (depending on the resin:hardner mix).
    Bondo is a brand name and may not be known here. There are similar body fillers available used for automotive bodywork. Here is one such local manufacturer, http://www.gkionline.com/
    Cheers.
    Jun 2007
    Quote Originally Posted by rohansharma View Post
    You fabricated what with MSeal ?? .. I would like a pic of this work of art.
  1. Discussing Cone Material
    By RedGTiVR6 in forum High End Solutions
    Last Post: 03-17-2007, 12:41 PM
  2. 1997 jetta fabrication
    By djatmospherere in forum Fabrication
    Last Post: 01-23-2006, 07:13 PM
  3. Need to hire a fabrication expert
    By vladilen in forum Fabrication
    Last Post: 06-16-2005, 01:29 PM
  4. Custom Fabrication Work?
    By mattdisaster in forum Fabrication
    Last Post: 02-01-2005, 12:37 PM
  5. what kind of material to use
    By marsjell in forum General Hardware Discussion
    Last Post: 06-23-2002, 03:33 PM
