Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: my first pc case
  1. #11
    Sep 2007
    Export, PA
    i use 1 large peice for the whole box...only the sides and bottom have a seam and when done right, those disappear...
    a circle cutter will help with fan holes. I used to use them all the time for ports and fan holes, but over time, my skills with a jigsaw improved and now i can use a jigsaw to cut perfect circles..... A circle cutter is a great way to get smooth round holes..its the kind you put in a drill and he has a drill bit in the center...
  2. #12
    Sep 2007
    hehe nice box sxtnitehawk, I haven't seen kitchen handles used on a pc box before.... not my cup of tea, but at least now I know what it looks like . Also to note, when nailing up the box with 12mm mdf (thats half an inch?) make sure you stay like 50mm (2 inches) away from the edge of the board, otherwise it will split. Also since you are using 12mm board, it will prove to be quite difficult not to skew the nails (coming out the side of the board), make sure the nailgun is exactly on a 90 degree angle, you've got plent of time so just take it slowly. The smaller the nails you use the easier it will be, but when trying to make the board flush with a mallet or something, the smaller nails will tend to bend and the board will come apart. 40 - 45 mm is a good length.
    I don't know much about fiberglassing yet :P, I didn't think holding the corners with it would be that good though, does it even stick to mdf?
    sxtnitehawk, what is a Drywall T square? and what do you use to fix the the carpet down? I would use contact adhesive stuff, spray it on the carpet and on the box.
  3. #13
    Sep 2007
    i keyed the areas to get it to 'grab' onto itits quite tough. i might have to build another one to accomadate my m2 atx and not the normal atx one
  1. Hardware Review: Mobile Computing Solutions Mini-ITX case
    By Dingo509 in forum The Review Palace
    Last Post: 12-06-2007, 08:25 AM
  2. MDF PC Case. (Éire)
    By ryan-neil in forum Fabrication
    Last Post: 07-12-2007, 12:12 AM
  3. would a xbox case fit all the pc stuff
    By VW_Carputer in forum Newbie
    Last Post: 05-30-2006, 04:57 AM
  4. Book PC case
    By FreznoSmooth in forum General Hardware Discussion
    Last Post: 12-16-2000, 11:23 PM
