I think you should have mabye used thicker material for the sidewalls, probably more like 6mm MDF or something. and it looks like it would have been a pain in the *** to do the carpet, as in some places it looks as though its not molded around it properly, might just be the pics though. Like for instance in the window pic, u can see the carpet overlaying the plastic window slightly on the corner, but I'm a cabinet maker so im pretty fussy :P. Otherwise id say good effort with it, next time use a more study sidewalls, obviously its not a issue of weight as you've gone overkill with the base (25mm is way too much, heavy as too) try something like 10 - 18mm that'll be enough.
Should look shmick with the LED fans.
~Danz
LinkBack URL
About LinkBacks
I would hate it if I had nowhere to work.
