Results 1 to 7 of 7
Thread: Machining something really small, really cheap? Canada?
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    If I needed, say, a 1mm square piece of metal a few inches long, how easy is that to machine?
    Basically I need a Robertson Square screwdriver. Which is ubiquitous in Canada, but not here in the US.
    They come in standard sizes, #00 being the smallest.
    however, I can not find a single place that sells #00, only #0 sizes.
    Since the screwdriver would basically be just 1mm x 1mm x 5 inches or something, how difficult would it be to just machine from a larger square stock?
    (0.0%-) starting over
    iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    well im guessing you want tool steel, so its going to be expensive.
    how about this?
    http://www.mcmaster.com/itm/find.ASP...string=2634T14
    and then you can cut it to roughly the correct amount, and then finish sand it.
    i looked around for 00 robertson, cant find anything either.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
    Mar 2007
    Winnipeg, MB, Canada
    I don't think I've ever seen a robertson screw or driver as small as that. Maybe you could contact the robertson company ask what retailers are selling the #00 driver. http://www.robertsonscrew.com/
    Aug 2004
    Floreeda
    I looked a bit more into it. the #00 is still too large.
    1mm x 1mm is probably a proprietary size.
    I dont know if I need high class metal to make it, seeing as how its so small and under little stress from the nature of the slot.
    Oct 2007
    Brampton, Ont. Canada
    Have you found your screw driver yet. Would take much. Just take a 00 driver bit and mount it on an indexing fixture and five minutes of grinding time. Any machine grinding shop can do this simple operation.
    Low Bitrate kazzxtrismus's Avatar
    May 2007
    some folks in the states call the square recess...but 1mm is propriotary...try getting a small flat head in there.(corner to corner)...at that size it should work free.
    i'd send you whatever you need from here in toronto...just say the word
    06 Altima..SER front bumper.
    CAR PC.....soon to be true!!
    Oshawa Canada!!
    Dec 2007
    Calgary, Alberta
    Check with a really good Klien tools retailer... this sounds like the yellow dot robertson that many old telephone construction guys had in their tool belts. In the tel/elect trade it would have been a #4 (i think that is 0 in other schemes)
    T
