Page 4 of 4 FirstFirst 1234
Results 31 to 32 of 32
Thread: Third atempt of carpc install
  1. #31
    Mar 2006
    Colorado, but Canadian!
    looks good. Also looks like a lot of work!
    Any plans for molding a screen into the dash?
    1.9in x 2.9in -- 47mm x 73mm
  2. #32
    Newbie Seth_jxl's Avatar
    Jul 2007
    still getting noise on the lcd screen? If so first try using a shielded vga cable (the thick ones that you find on a lot of older crt monitors, you may also want to cover connections with alloy foil to prevent EMI. If this dsnt work one method i would suggest is using a Magenta Cat5e system however this may be costly for your application. But before trying any of this, you should attempt to remove the source of EMI, a neon transformer is a common culprit. and should be a minimum of 30 cm away from any audio or video devices.
  1. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 03:41 PM
  2. 350Z CarPC install.
    By TeaVirus in forum Show off your project
    Last Post: 08-13-2007, 10:33 AM
  3. XC90 Install - am I the first??
    By klokman in forum Worklogs
    Last Post: 02-13-2007, 12:12 AM
  4. Looking for someone to help with carPC install (USA-MA)
    By Kurack in forum General MP3Car Discussion
    Last Post: 01-23-2007, 01:56 PM
  5. Peugeot 605 TD Carputer install 8"TSK/GPS/DVD...
    By sixofive in forum Show off your project
    Last Post: 02-02-2005, 01:40 PM
