Results 1 to 10 of 11
Thread: Bezel from Scratch....
    Nov 2007
    My single din radio was removed. Dash was cut a double din was installed. The radio did not come with a bezel. There is not stock dash piece to start with to make a bezel from. What could be used to make a bezel? Keep in mind that the radio is mounted and dash can not be removed.
    Low Bitrate 20mg's Avatar
    Oct 2007
    chico ca
    check the sticky i believe there is a complete tutorial on it.
    Oct 2007
    chico ca
    yep there top sticky on this forum should help it shows a pretty detailed way to make one plus tells you all the stuff you r gonna need.
    Nov 2007
    I saw all of that except he was able to remove the stock radio bezel to mold a piece to. I have nothing to remove.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    What car is it? Can you fit a universal Double DIN Adapter?
    Nov 2007
    Quote Originally Posted by MGD View Post
    Not sure what that is? It is a 2000 VW Eurovan. There is no dash kit for a double din unit for the Eurovan.
    Oct 2007
    chico ca
    just try to get a universal double din adapter. if your van is double din it will fit. and that would be a good place to start off with your custom bezel.
    Oct 2004
    Sydney, Australia
    Check out my worklog for a method using fiberglass.
    Continued Worklog... Upgrades in progress:
    *15.4" WXGA LED backlight touchscreen upgrade
    *Custom fiberglass dash bezel
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    ...or my sig for making a pattern and casting it.
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    some photos of your dash would help...
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
  1. Replies: 302
    Last Post: 03-16-2012, 04:29 PM
  2. Fabricating buttons on a bezel.. need help
    By gps in forum Fabrication
    Last Post: 01-17-2007, 11:24 PM
  3. Replies: 10
    Last Post: 12-18-2006, 08:50 PM
  4. Fiberglassing Gauge Pod in Bezel *pics*
    By jmilin5931 in forum Fabrication
    Last Post: 10-04-2006, 08:04 AM
  5. 2002 Silverado Custom Dash Bezel
    By AZ_Silverado in forum Fabrication
    Last Post: 08-09-2006, 01:46 PM
