Results 1 to 4 of 4
Thread: How to hold up the rings??
    Nov 2007
    Hey guys, I am new to fiberglassing and I started a project in my rsx and its turning out like it should, but I get to the part where I need to mount the mdf rings to the box with dowels. My question is what glue did you guys use to hold the mdf ring to the fiberglass and to the dowels? Also is there an easy way to hold the rings up instead of me holding the rings till they dry? Thanks you guys for lookin and helping.
    Jul 2007
    I believe most people recommend/use a hot glue gun.
    Hope this helps,
    Nov 2007
    Yea I have read about people using that, just wanted to know if hot glue is going to dry real fast and so I dont have to hold the dowels thanks again. Also I went to a car audio place to ask what they used as glue and they said some kind of metro glue? If you know about this and if it works let me know how it does and where I can get some thanks
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    hot glue is really more of like a wax/plastic mix, when heated becomes a liquid/gel, and once cool solidifies again, so there is not drying time persay, just a short cooling time. real short.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
  1. Press and hold to tilt
    By ga_zander in forum StreetDeck
    Last Post: 08-08-2007, 04:48 PM
  2. Replies: 4
    Last Post: 07-15-2005, 12:52 AM
  3. MDF Rings
    By Giwo in forum Fabrication
    Last Post: 03-23-2005, 05:42 PM
  4. Help in need to get hold of 10.4" lcd
    By johnemerson38 in forum LCD/Display
    Last Post: 10-05-2004, 01:32 AM
  5. Can double din hold pull out and radio?
    By jnusaira in forum Fabrication
    Last Post: 06-08-2004, 04:32 PM
