Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: stock color dash paint
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    edmond, oklahoma
    is there a paint or a way to find the color code for my interior plastics? its a 98 blazer LT with all tan interior. i have a spare dash bezel im hacking apart to fit my screen. but if it comes down to having to make it smooth, i would like to paint it to match my interior. if need be and i buy a 02/03+ dash bezel that is DD, what do i need to paint it to match my interior? the DD dash bezels do not come in tan, whick kinda sux. but how would black or charcoal grey look on a tan interior to all of you? the dash bezel looks like this...
    well as i was looking for a picture of the dash, i came across the perfect one. its from a 99 bravada. i cant really tell if the color is the same as my interior.
    Nov 2007
    black usually goes with anything as far as i know...
    As far as painting, the interior paint work I've done included these steps:
    Light Sanding
    Cleaning
    Degreasing
    Priming
    Painting (multiple layers, duh)
    Clear coat...
    Apr 2007
    edmond, oklahoma
    sounds good, but i want it to still have that stock texture. i think i can skip that sanding, even a little bit. as long as its clean, it should stick. i did use some black interior oaint once in my 95 taurus dash bezel. it was grey. like this one i have now. and i painted it black. it stuck and looked nice. is there a clear coat i can get thats not glossy?
    Low Bitrate slinkytoy's Avatar
    Mar 2007
    Colorado
    You can call or go to your local car dealer and get the color number for your blazer. Also you can use texture paint that is pretty close to what is in the blazer now. 3m makes some good spray on paint. I have use it and it takes a little trial and error to get it right. The trick that i found was to let the texture dry then take 400 grit wet sand paper to it lightly and see how it looks. I put 2 layers on my dash bezel and it turned out pretty good. Yes there is a clear coat that is not glossy SEM paint makes it.
    http://www.sem.ws/index.php
    Look thru the web site all you need it in there.
    Nov 2007
    Call a local auto upholstery shop and find out what/who they use to dye their dashes. There are several products that I have used in the past that work great. The best and usually easiest to find is the SEM aerosol. here is a link to it: http://www.sem.ws/product.php?product_id=190 on the right side of the page is an expandable color pallet. good luck!
    Apr 2007
    edmond, oklahoma
    i like the idea of contacting a custom upolstry shop. im going to do that probably tomarrow morning.
    Nov 2007
    cookeville TN
    Hello
    I hope I caught you in time. This is an easy diy. The interior code is in the glove box on a sticker. At the bottom of the sticker it will start like this BC/CC wa8555 or something close thats the paint code. If it is two tone or has trim it will be followed by another wa1234 or similar that is the trim code. Then directly out from that on the same line there will be another. That is the interior code. If you are not painting anything that is soft(vinyl,leather,or carpet) I wouldnt use sem or any other dye. Paint store can just mix a paint made for interior. If you are painting something soft and something hard use sems brand, and spray adhesion promoter on the hard surface. If you do not have a paint gun keep looking for a paint store that can mix paint and put it in a aerosol can, they are out there. Like everyone else said clean first. It is the most important part. First use soap and water and the preclean wax and grease remover.
    I hope this helps
    If you can't find the code. Post the color of the vehicle and Ill be able to help. Im looing at the GM book and seeing like 14 interior colors that could be described like that.
    Im out
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    Often on many GM panels, you can flip it over on the back, and it will have the OEM color standards on it. Like on my 96's door panels it has "RUBY RED" stamped on it, and some OEM standard, which should be something with 9933 in it. It should have more than one standard listed, just as my panels do.... One for the accenting black, and one for the color.
    Play with it, 'til it's broke.
    Apr 2007
    edmond, oklahoma
    the only spot i have with something stamed in says:
    pmp abs pc cav 3
    p\n 15004627
    Gathering parts----99% (I'll always want something else, its never 100%)
    Learning Centrafuse
    First Actual 98 Blazer LT Install
    First 08 Aveo5 SV Install
    87 Fiero GT waiting
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    I'm not finding anything on that p/n... Look in the glove box for the W #'s.
  1. Paint Clarifications
    By ctsoccer13 in forum Fabrication
    Last Post: 06-15-2007, 12:14 AM
  2. To paint or not to paint
    By cavramair in forum Car Audio
    Last Post: 05-21-2005, 03:59 PM
  3. SEM paint
    By Quattro in forum Fabrication
    Last Post: 04-09-2005, 03:00 PM
  4. Very Unique Bondo Problem! Paint Screwing it up?
    By Grayscale in forum Fabrication
    Last Post: 01-09-2005, 12:34 PM
  5. Replies: 13
    Last Post: 08-22-2004, 05:52 PM
