Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Gluing vinyl to plastic
    Dec 2007
    Boulder, CO
    I need to glue a small piece of vinyl (finished side against the glue) to a piece of plastic. This joint will need to hold a bit of tension. Anyone have experience with a good product?
    Maximum Bitrate redls1bird's Avatar
    Feb 2006
    Atlanta Ga.
    Ive only heard good things about Gorrila glue, but cant attest to its strength. I suggest a few trial runs to find what works best for you and your application.
    Car Pc progress meter:
    [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
    Dec 2007
    Boulder, CO
    Ok, cool, thanks! I'll check it out
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    the only concern i'd have about gorilla glue is that it needs moisture to cure properly. Sometimes there's enough in the air to do it, but i think you might have better luck using PL construction adhesive. It's thicker like peanut butter and might make it a little easier to work with. Cure time is about 24 hours though. I've had good luck with it.
    Mar 2007
    Central Florida
    Contact cement is excellent, but I don't know specifically which kind. It's what is used to clue formica down to pressboard. It's also used to glue your sneakers together.
    Jun 2006
    Denver, CO
    booksix: maybe you can post pictures of what you're trying to do. Something in my gut tells me there might be an easier way.
    Dec 2007
    Boulder, CO
    ok, thanks, I will when I get home from work...
    Dec 2007
    Boulder, CO
    Ok, here's the deal. I'm adding 6 buttons (factory cruise buttons modified from resistive to momentary) that interface with a Targus wireless keypad PCB and transmitter. The transmitter is held in a cavity which is covered by the original vinyl that was peeled back. To hold this flap in place, I want to glue the top edge of it to the ABS plastic cover seen in the pics below. The glue will hold a bit of tension, but not much.
    Dec 2007
    Boulder, CO
    So whatever happened here, gohybrid? I got the pics up for you and you disappeared! LOL
    Jan 2007
    Northeast, USA
    According to:
    http://www.thistothat.com/cgi-bin/gl...l&that=Plastic
    you can use:
    3M 30 for flexible bond
    hot glue for a rigid joint or
    household goop (E6000 Glue)
    I will not advise the Gorilla Glue, makes a real mess, cannot be controlled well and it is very hard to clean.
  1. Plastic Welder - anyone used?
    By evandude in forum Fabrication
    Last Post: 11-15-2010, 10:55 AM
  2. Plastic Weld?
    By slboytoy in forum Fabrication
    Last Post: 08-31-2006, 11:51 AM
  3. Fiberglassing over a vinyl dash
    By tml240 in forum Fabrication
    Last Post: 08-30-2006, 12:19 AM
  4. 99 Honda Prelude Carputer wrapped in Vinyl!
    By SuperDave01 in forum Show off your project
    Last Post: 10-10-2004, 02:19 AM
