Results 1 to 2 of 2
Thread: Custom CarPC Case
    Jan 2008
    Custom CarPC Case
    I am interested to a make a case for my carpc and I am on tight budget. I would a opinion from you guys on here to guide me through this fabrication. I was thinking about using MDF board. What the pro and cons from using this type of material? I plan to put three fans in their to keep the case cool. The measurments will probably be 12" inches long 10" wide and 5" deep. Thanks in advance Mike
    [Pic]http://i87.photobucket.com/albums/k143/prop7459/StealthSig1.jpg[pic]
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    I sell some cases that are custom built, but kinda expensive. but they are 12''x 11.2'' x3.7''
    micro-atx motherboard fit right in (9.6'' x 9.6'' board size) It has hdd rubber bushing for suspension for a 3.5 hdd. mounting for three internal 80mmx80mm fans, and mounting for an opus 150 or 180 power supply. here are some pics. the case you can paint to match your ride. case cost $145.00.Custom slim clear-anodized aluminum Micro-ATX enclosure, designed for maximum cooling and air-flow.
  1. Custom 1.6mm Thick Aluminum Carpc Trunk Case
    By LiquidKernel in forum Fabrication
    Last Post: 06-08-2008, 02:52 PM
  2. (VoomPC) Ampie Case Custom Wiring Harness
    By salvi in forum The Review Palace
    Last Post: 11-25-2007, 11:07 PM
  3. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  4. Keyboard language indicator extension plugin
    By tolisn in forum RR Plugins
    Last Post: 09-13-2006, 04:49 AM
  5. Audi A6 custom install carpc with fingerprint recognition
    By ejdeleon in forum Show off your project
    Last Post: 07-07-2004, 04:25 PM
