Results 1 to 4 of 4
Thread: '95 Accord lill bezel first try
    Newbie ali7up's Avatar
    Feb 2007
    Georgia
    '95 Accord lill bezel first try Help!
    here is my first try at custom bezel with 7" lill i will post picture as i make progress, any tips, comments would be great
    Supplies:
    After Epoxy Glue:
    After Bondo Glass:
    Bonds Glass again after sanding:
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Looks okay. stay away from the inner edges of the screen, you dont want to have to correct those and have it mis shapped.
    Feb 2007
    Georgia
    well after two rounds of bondo glass and hours of sanding, it looks like this:
    is this good or should i apply more bonda glass if not bondo filler thanks
    May 2007
    Before you add any type of filler, that needs to be sanded down even and all the bondo glass needs to be removed from the button areas. Take a flat head and break out the filler in the holes. You want the bezel completey even with the body glass, and then to just use the regular body filler to get a smooth surface. Prime, then refill with your putty any pinholes, prime, re sand
    If you give up, send it to me, I can finsih it perfectly
  1. 10.4" Screen in 95 Accord.. First Build.
    By rob1218 in forum Show off your project
    Last Post: 05-22-2007, 10:11 AM
  2. FS: 7" VGA Module or 04 accord bezel
    By calvincbr in forum Classified Archive
    Last Post: 02-20-2006, 08:10 PM
  3. 98 Accord with Xenarc 700TSV bezel fabrication
    By Dracord in forum Fabrication
    Last Post: 02-07-2006, 12:35 PM
  4. FS/FT: Fabricated Accord Cubby Replacement Bezel
    By damixt in forum Classified Archive
    Last Post: 10-12-2005, 02:50 PM
  5. 95 Honda Accord In-Dash Install
    By Gewehrschuss in forum Show off your project
    Last Post: 01-24-2005, 12:52 AM
