Results 1 to 8 of 8
Thread: Acrylic Resin and LED's
    Nov 2004
    I have an idea for some accent lights where I'm wanting to put some LED's and accompanying circuitry in acrylic resin and my question is about light dissipation. In what way, good or bad, will this effect the light thrown out by the LEDs? Also I don't think it will, but any chance circuitry (i.e. some resistors) be affected by the acrylic resin after it dries?
    Jul 2006
    Well, I think a lot of how the light will dissipate will depend on where you place the leds, as well as the surface texture of the the part you are lighting. If you place the leds on the edge of the piece, and the surface texture is smooth the leds will light the edge of the acrylic and not much else. It you rough up the surface, the light will scatter off the surface and light up the part better.
    A lot will also depend on the optical clarity of the resin you use and how well you get the air bubbles out.
    Oh, and I don't think you would have to worry about messing with the circuity if it is cast in the resin. Plastics are typically poor conductors of electricity.
    Nov 2004
    Quote Originally Posted by LYHTSPD View Post
    Ok, so what I'm trying to do is make the leds just shine through the acrylic and not really light the acrylic up, if possible. I mean I know the plastic will glow alittle but I'd like to keep it at a minimum. So according to the above I should just keep the resin untouched instead of sanding the surface?
    Here is a crude illustration of how I want the leds aligned.
    Jul 2006
    Yes, if you keep the surface clear (untouched) and mount the leds perpendicular to the surface, they will shine through (just like glass).
    Nov 2004
    Perfect! Thanks lyht!
    Jul 2006
    Just remember, the more imperfections in the resin, the more the light will scatter. You want it to be as clear and as smooth as possible. Good luck, and post results!
    Aug 2007
    Lake Charles, Louisiana
    Try to grind the LED heads flat, but not so far as to get to the diode. This is dispurse the light come from the LED into the acrylic and will virtually elimate any hotspots.
    2000 Pontiac Trans Am Firehawk #102
    Processor: AMD 64 X2 BE-2350 (Dual Core)
    Motherboard: ABit NF-M2S (Micro-ATX)
    Memory: 2GIG Crucial DDR2 667
    Hard Drive: WD 160GIG
    Monitor: 7" Lilliput 629GL
    Front End: CentraFuse With Navigation
    Jul 2006
    Quote Originally Posted by InfiniteReality View Post
    I don't think he was wanting a dispursed light from his posts.
