Results 1 to 3 of 3
Thread: Small project
    Jan 2008
    Southern Calif
    Small project
    I'm working on this little project for my EQ dash controller. I pretty much cut a semi rectangular hole on the plastic panel and glued on the device on it. The plastic epoxy kind of filled the gaps however there's some parts with holes showing up after I primered it.
    I tried applying a layer of bondo but after sanding it down, there's not much bondo left. I can see little bit of pink where the bondo has filled up small holes, but very little. Do you guys think I should try to carve out the glue where I see holes so that I can apply bondo and on it?
    Maximum Bitrate redls1bird's Avatar
    Feb 2006
    Atlanta Ga.
    Try some filler/glazing putty, its made for small imperfections like what your talking about. Expect to do more than one coat though for good results.
    Car Pc progress meter:
    [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
    Jan 2008
    Southern Calif
    I dont know if it's just me but I think its alot harder to try and flush mount it, than to have it stick up a little and then bondo'ing around it. Thinking of maybe unglue'ing it and raise it up a little something maybe like this..
  1. Replies: 30
    Last Post: 07-28-2010, 11:14 PM
  2. Ambitious Pico-ITX-based Car PC Project
    By Kenshin5 in forum Newbie
    Last Post: 12-18-2007, 05:14 PM
  3. The Vectra CarPC / CarPuter Project v2
    By ccsnet in forum Show off your project
    Last Post: 08-29-2005, 06:46 PM
  4. Carputer as a comp sci final year project?
    By MikeHunt79 in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:19 AM
  5. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 06:43 AM
