Results 1 to 10 of 18
Thread: Need ideas - Dash opening bigger then screen bezel
    Jun 2005
    Atlanta, Georgia
    Question Need ideas - Dash opening bigger then screen bezel
    Okay, so I'm looking to the experts here for some ideas on how to work on my bezel for a '07 Grand Cherokee. Basically, I have the opposite problem that most people have -- I have a huge opening in the dash, bigger then the bezel and so I need to fill in about 1" of area on 3 sides.
    Pictures will explain much better, but only small chuckles at the horrible photoshop mockup are allowed! [click picture for larger version]
    Before showing dash area...
    Mockup with 7" Lilliput and slot loading DVD drive....
    My main concern is the best way to fill in the areas oulined in red, since they are about 1" on the left/right and about 1.5" on the bottom...
    I do not want any seams showing around the bezel or the DVD drive, so that the whole opening (in black) looks like it was made for the LCD and the DVD drive is just the slot and eject button.
    I read the many posts and stickies with what people have used, but there are lots of options it seams and sourcing some of the recommended stuff is hard now.
    ALSO .... if there is anyone with experience that may want to work on this job, please PM me. Open to discussion, and I already have all the parts so all that is needed is the dash work.
    Low Bitrate TheSovereign's Avatar
    Feb 2008
    Nu Yawwwk
    Too bad there doesn't seem to be a headrest shroud available for the Lilliputs... that would have been my suggestion... sorry I can't really be of much help when it comes to the fab... perhaps a sheet of plastic or plexi to fill the gaps?
    Banned
    Jan 2008
    Fill it in with puddy.
    Feb 2008
    Nu Yawwwk
    Actually, it probably wouldn't be that difficult to create your own fiberglass "shroud" ...
    Not being a fiberglass pro, the way I'd perhaps try to go about that would be to wrap the Lilliput housing in aluminum foil, give it a coat of vaseline or whatever, flip it facedown, and then lay down the fiberglass mat and resin... of course you'd need to coat whatever surface you were working on with vaseline as well, but that would give you a flat surface to create the "wings" that you're going to need to fill the gaps...
    I hope that makes sense, and like I said, I know very little about fiberglassing, so hopefully the pros will point out any inconsistencies, problems, or errors in my thought process.
    Jun 2005
    Atlanta, Georgia
    Here's a better picture of the "gap" size that would need to be filled, extending from the side of the dash bezel to the LCD bezel....
    @TheSovereign: Yea, that was what I was thinking from the pictures in your post. Would have been perfect <g>.
    @wjc04wrx: What type of putty you recommend/referencing? The locktite brand putty or something else?...
    (Note: Although it looks like there is metal in the "gap" on the left side, this is just because of the angle of the picture. The metal is behind the existing "black" part, and not really something that can be utilized easily as it's about 1 in behind the work area
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    There are several threads here on MP3Car.com that describe this operation, including turbocad6's sticky thread on how to make a factory bezel, right at the top of the Fabrication page. Materials used in these projects include ABS, fiberglass, metal, even fiberboard (Masonite). There are lots of ways to do it, many of them detailed extensively right here.
    One other way to make that gap smaller is to use a bigger screen . . .
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Variable Bitrate super-fly's Avatar
    Feb 2006
    NJ
    i would get a bigger screen
    Banned
    Jan 2008
    I thought about the bigger screen as well, but it looks like he already has that screen.
    Do you want to mold the screen into place, or do you want to make the bezel look as if you can just place it in there like if it were an OEM piece?
    You can use the loctite or other type of puddy, i think that Walmart carries one. Have you ever attempted to do something like this? Would you consider paying someone to do it instead?
    Jun 2005
    Atlanta, Georgia
    Thanks for the quick input everyone... this forum is more alive then I thought (either that, or I've just read to many old posts from 2006 and 2007!)
    Can't do a bigger LCD screen, since I already have this one. I wanted to get a transflective, since a lot of sun hits that area with the sunroof open. Also, a 8" widescreen would have fit much better, but not leave me enough room for the slot DVD drive below it (non-negotiable part).
    @wjc04wrx: I want to mold the screen it into the dash bezel itself, as one unit. Basically, what I'm going for is no seams on the "black" part, just the cutout for the LCD screen and the slot/button for the DVD drive.
    @rdholtz: I've gone through all the stickies, but also found turbocad6's input into the long 20+ page "ABS sludge" method which I missed before. It seams like the dynatron product would be great, but can't find anywhere around me that stocks it. Repair shops here all order their repair stuff out of state, and I can't find SEM products around here either (though if anyone ever needs every color of Krylon Fusion or generic "auto-zone style" auto paints let me know... sheesh). Any ideas where it can be found online?
    If I find it, what would you recommend to bridge the 1" gap or so? I imagine having to place some flat material to bridge the gap, then put the dynatron on top of it?
    Feb 2006
    NJ
    http://cgi.ebay.com/ebaymotors/Dynat...3286.m20.l1116
    I would just use foil like the sticky shows to go between the gap.
  1. 2007 Mazda 3 Dash Screen looks OEM
    By Splash-X in forum Show off your project
    Last Post: 05-04-2009, 05:29 PM
  2. Ideas for making a hinged opening in the dash
    By ankur in forum Fabrication
    Last Post: 09-18-2006, 02:36 AM
  3. Free-mounted Screen outside dash - is this GHETTO?
    By smellygas in forum LCD/Display
    Last Post: 04-05-2006, 02:07 AM
  4. Wiring in dash screen: How-to...
    By marzman in forum LCD/Display
    Last Post: 05-29-2005, 07:38 PM
  5. 7-in in dash screen question
    By traitorhound in forum LCD/Display
    Last Post: 04-07-2003, 07:42 PM
