Results 1 to 9 of 9
Thread: RepRap - Rapid Prototype Machine Project
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Heys Guys,
    I thought a few of you might be interested in the RepRap project. It is basically a project to create a DIY rapid prototype machine for about $400GBP. Once built it is able to create the parts required to build another machine - it can build itself.
    It's a great idea, the plans are free and development is ongoing. You can see more info on the project at the RepRap homepage.
    I installed my carpc into my pet Kangaroo, mate.
    Mar 2006
    Colorado, but Canadian!
    3D printers are awesome. One of the few toys I havent been able to get my hands on. When we got the laser cutter these 3D machines were upwards of $70k USD. Laser was only $28k USD
    Only problem is the cost of the powder/goo that the UV beam reacts with.
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2006
    The RepRad doesn't actually use the powder/laser system. It uses coils of HDPE, heats them up and extrudes them onto the work surface and builds up that way.
    Mar 2006
    Interesting... HDPE is high density poly-propelyne or however you spell it right? Can you use the stuff at the hardware store?
    Did you build one?
    Variable Bitrate quantum's Avatar
    Sep 2005
    Quote Originally Posted by 2k1Toaster View Post
    You have a laser cutter? Can we be best friends?
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    No, it's high-density polyethylene. Different stuff.
    It's what my Scion xB dash bezel is made from, and I'm building a revised bezel with it. There's information on polyethylene -- including sources -- in the worklog in my sig. See posts 17, 21, 30, 31, and 59.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Nov 2006
    @ 2k1 - Nah, I haven't built one yet. I only stumbled across the information yesterday.
    I've got a couple of projects lined up at the moment (don't we all), but this is definatley something that I'd really like to build down the track.
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by quantum View Post
    You want a laser cutter to go with your RepRap? Here's an Instructable that says you can make one for under 50 bucks. I confess that I haven't made one myself, either, but it is tempting. I think I oughta finish the CarPC project first.
    Mar 2006
    Quote Originally Posted by rdholtz View Post
    200mW laser?
    The old one i use is 30W. Has a tube about 1m x 25cm x 25cm. Tube alone is $600USD
    If this thing could cut through wood/plastic (3mm to 6mm minimum) then I would build one, even for $1000USD. But 200mW from an optical drive, is a little useless for anything but vinyl. Still good to know that people are making things, that semi-work!
  1. Ambitious Pico-ITX-based Car PC Project
    By Kenshin5 in forum Newbie
    Last Post: 12-18-2007, 05:14 PM
  2. New project please help with some questions
    By gt__1 in forum Fusion Brain
    Last Post: 10-05-2007, 02:49 PM
  3. Google Dashboard prototype (announced as project)
    By dazuck in forum General MP3Car Discussion
    Last Post: 01-07-2006, 12:39 PM
  4. DIN compatable PC project
    By don-m in forum Worklogs
    Last Post: 10-23-2005, 11:11 AM
  5. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
